Question about Dishwashers
Error Code E4 on my Candy CDI 45 Dishwasher - Dishwashers
Get you get it fixed? I have the same error
Posted on Jan 24, 2011
We have a belini dishwasher with E4 error code what shuld we do?
Hi, there is a few things that can cause the e4 code......
overdosing the machine can cause excessive foaming.adding soda crystals can also cause this (by clogging) or water pressure is to high.
turn off machine then tilt it backwards about 45 degrees (so it does not upset the water management system) and the water should drain away solving the error code.Hope this helps
Sep 22, 2012 | Office Equipment & Supplies
Error E1 on Candy dishwasher CDI 45
Hi
E1 is a leakage error in your dishwasher; it is usually displayed either due to a clogged drain or due to water leakage in hose connections. If the drain pump assembly is not clogged then check the motor water seal leakage of sump assembly and also check the impeller of washing pump, if it is worn then replace the impeller. You can also make sure that the height of drain hose is not over 20". Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | Dishwashers
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
I have a Candy dishwasher. Door is open switch on sounds like something (possibly pump) is running and error E4 shown on diaplay. Any ideas please?
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
Jul 20, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Getting an E4 error message on portable dishwasher - Kenmore 18" ,mg DDW1805W.
E4 means the overflow sensor has activated.
Under the washer is a pan - with a sensor. If it gets any sort of water - it activates.
You can remedy this issue by pulling ut the dishwasher, and tilting it up to about a 45 degree angle to empty the catch pan.
This should solve your problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 14, 2009 | Kenmore 17459 Free-standing Dishwasher
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
I have a kenwood KDW12SL3A. The Drain got blocked at the dishwasher end, and I have now unblocked and tested the drainage but have still got an E4 error come up. how do I reset this?
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
Jun 23, 2008 | Dishwashers
Dishwashers Logo
1,213 people viewed this question
Top Dishwashers Experts
