Question about Whirlpool Dishwashers
I just moved and now have a much older whirlpool dishwasher - the only words left on it are "sound conditioned" - model # is worn off too. The condo was built in 1980 ish and this is original appliance, It has the knobs on the right side and it is a push/pull to turn on/off. Problem - I use soap tablets - not ejecting from dispenser - should I be using liquid soap in this oldie - but goodie?? Thanks
  • 1314 Answers
SOURCE: Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Posted on Jan 31, 2008
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
  • 1073 Answers
SOURCE: i have a kenmore dishwasher.
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Posted on Apr 10, 2008
SOURCE: Dishsoap stays in soap dispenser
We had problems with soap remaining in the dispenser and dishes not getting clean when we used gel dish doap. We changed to the cakes of soap with a Jet Dry Power Ball in the middle, and now they clean fine.
Posted on Apr 14, 2008
ngfam1
  • 639 Answers
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
Part 763-8530 for Miele Dishwasher
Check with a local appliance parts supplier or go to www.repairclinic.com and enter the Miele model number.
May 06, 2012 | Miele Dishwashers
Hi, my dishes are not getting clean, dirty residue is left in the washer. Is it not draining? The machine was here when I bought my condo, so I don't know how old it is. Thanks!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 27, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
2-3 inches water left in bottom of dishwasher after it finishes it's cycle model DU81OCWDQ5
The model number of your dishwasher is DU810... (zero not O).
Please refer page 28 of user manual. It is normal for some water to stay at end of cycle. However, check if the air gap (if insalled) is clear. Also make sure the kitchen side of drain hose is clear.
Unless there is a fault condition shown by flashing lights, then it is pretty normal operation.
In case in future you need to refer to the parts of your dishwasher you can refer this site.
Jan 02, 2011 | Whirlpool Dishwashers
My Frigidaire dishwasher won't start. I just moved into a condo and the dishwasher worked during inspection but now it's not...wondering if it's something I just don't know about. The model number is...
Did you ever get an answer to your problem.
I've got same issue where I turn the diswasher on and nothing happens ... the time just start going down but nothing is happening?
May 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Just moved into a condo with a whirpool tub. the
Jets are in the closed position or the pump is shot.
Sep 25, 2009 | Home
The door to my miele dishwasher does not spring closed and just lies flat when opened
The operative word is spring[s]. There are two springs to assist in lifting the door. One on each side. If your dishwasher is an older modell it is time to replace the springs because they are worn out.
Jul 18, 2009 | Dishwashers
Whirlpool model shf 5800 will not drain completely
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Jun 02, 2008 | GE Dishwashers
Philips Whirlpool Integrated Dishwasher
Model numbers that are worn or missing are hard to find. When you go to whirlpool's website you might find your dishwasher there, other wise it might not have them listed because it is obsolete.
One place to look is on the panel below your dishwasher door. In some cases it is stuck there, or somewhere else under the dishwasher.
I have seen them inside of the dishwasher housing (under the cabinet between cabinet and dishwasher.
Very rarely will you find the model numbers inside of the dishwasher doors. However according to Whirlpool, if you open your door, you will find a sticker or a riveted plate on the right hand side of the dishwasher's frame, near the seals.
One thing I suggest however once you have discovered the model number, write it down and put it someplace safe.
Good luck
Apr 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
108 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
