Question about Casio Exilim EX- Z200 Digital Camera
Why am i being told the card is locked when it isn't
    Brigadier General:
  • 11,967 Answers
Are you sure the slide switch on the side of the card is in the unlocked position?
Posted on Oct 12, 2010
Says memory card protected when I try to use it
If card lock button isn't faulty and doesn't free by sliding it a few times does your camera have a memory lock function in the menu?
Sep 27, 2012 | Panasonic Lumix DMC-FZ7 Digital Camera
Installing SD card in desktop
try using an adapter that you can use to put the sd card in and plug it into the USB drive. The only thing I can come up with is either there is a lock on the sd card, or that slot isn't designed for sd cards but for other cards.
Jul 28, 2012 | Cameras
Memory card locked! My camera suddenly gives this error. I have already checked if actually the card is locked but it isn't. I have also formated the card, and tried with another card: the camera gives...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Oct 24, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Memory Stick Duo 512MB. Where are no pictures on the card, but it says that "were is no space" when I put it in the camera. What should I do?
First make sure the card is not locked. Do this by checking on the side of the card that the lock notch is not in the locked position. If it is not locked then you should put the card in your computer and reformat it. If this isn't successful then its time to go get a new card. You can get a new one for under $20.
Aug 26, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
I cant move songs to sd card because of write protection
Hi there, It sounds like your SD card is "locked" - take a look at this picture -> http://www.google.com/imgres?imgurl=http://btechzone.com/wp-content/uploads/2010/07/SD-Card.jpg&imgrefurl=http://btechzone.com/know-the-basic-benefits-of-using-sd-card&usg=__iHi-tsmpfGjNHEGmrDcRQBQHymg=&h=937&w=750&sz=296&hl=en&start=0&zoom=1&tbnid=kRsh2ndRsYB3EM:&tbnh=133&tbnw=111&ei=kQjkTb_bK8eztwfYyIChBw&prev=/search%3Fq%3DSD%2Bcard%26hl%3Den%26biw%3D1034%26bih%3D584%26gbv%3D2%26tbm%3Disch&itbs=1&iact=hc&vpx=123&vpy=92&dur=124&hovh=251&hovw=201&tx=132&ty=147&page=1&ndsp=18&ved=1t:429,r:0,s:0&biw=1034&bih=584 On the left side, you should see a white switch. The label points out that if the switch is in the down position, the SD card is locked. Take a look at your SD card and make sure that the switch isn't in the locked position. If your SD card isn't labelled, I'd switch the position of the switch and try to copy the music again.
If that doesn't work, right click on the SD card in My Computer, and Click format. Do a quick format on the SD card and see if that helps.
Alex
May 30, 2011 | Computers & Internet
Says Card Error
Make sure your camera can take San Disk. It probably takes a certian card or the SD card might be upside down. Some brand and models stay this fault and the problem with the SD is that it does not accept a memory card higher than 1GB. This info isn't in the user guide. Have you tried an external usb card reader?
Pull the card out and re-insert. the most likely problem is the card was not seated properly in the slot.
Keep us updated.
May 17, 2011 | Vivitar ViviCam 5386 Digital Camera
WHEN I INSERT MY MEMORY CARD IN MY SONY CYBERSHOT DSC W510 IT SAYS MEMORY CARD LOCK.....HOW CAN I UNLOCK THIS ?
Hello there And Welcome to Fixya !
First of all there isn't any problem with your memory card or camera .
Take out the memory card from your camera and take a look at memory card , there will be a lock pin on the memory card .just unlock it with your finger cause it has a tiny knob
Do comment if it helps you in any manner
Apr 26, 2011 | Sony DSC-W510 Digital Camera
Turned on camera (Canon PowerShot SD1100 IS) and was told that the card was locked! How did this happen and how can I unlock it?
Aug 14, 2010 | Canon PowerShot SD1100 IS Digital Camera
Casio Exilim EX- Z200 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
