Question about Brother Sewing Machines
Ce 5000 prw - upper thread bunching up on underside (lower thread ok), all stitches coming out strait or partial pattern then strait
  • Brother Master
  • 7,365 Answers
Try changing the needle
also check the top thread tension
check for lint under needle plate
some needles & thread aren't compatable--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Oct 12, 2010
What is wrong when the underside of embroidery has bunched thread
Hello
The bunched-up thread on the underside is the needle thread. Check that the upper thread is threaded correctly, passing through all the required thread guides and that the thread is securely lodged in the tension assembly ... there should be reasonable tension when upper thread being pulled by hand.
Also check that:
- there are no 'dust bunnies' or a piece of thread hiding in the tension assembly, and that
- the needle is inserted correctly and that it is a system 130/705H Embroidery needle.
Happy Stitching
Sewingirl/
Apr 23, 2017 | Sewing Machines
When i run a straight stitch, the top of the fabric looks well sewn; the thread on the bottom of the fabric, however, bunches up-it looks nothing like the top stitch.
Is it really the bobbin thread that is bunching under the fabric, or is it really the top thread that is creating loops and "bird nests" under the fabric???
Rethread your upper thread. BEFORE you thread the upper thread, be sure to RAISE the presser foot. This releases the upper thread tension disks so the thread is firmly seated in the tension disk.
If it continues to be a problem, then the upper tension needs to be tightened. Adjust slightly, then test. Repeat until the upper and lower threads meet in the middle of the fabric.
Sep 24, 2015 | Sewing Machines
The thread for the top needle just sews and loops onto the lower thread
I think you are saying that there is a loop showing on the bottom of the lower thread stitch. If the lower stitch looks correct and not bunching, you will need to change the tension on the upper stitch. Make sure that your threads are firmly inserted within the discs also before adjusting the tension. It doesn't take much to change the tension so take it slowly.
Dec 31, 2013 | Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
CE-5000 thumping sound when I sew, messy stitching
any sound out of the ordinary could mean that a part is worn or fixing to break or something is loose
it's very possible that the machine needs to be serviced
Feb 08, 2012 | Brother CE5000 Computerized Sewing Machine
My machine is stitching, it just keeps bunching on the underside of my material and I end up with this wad of thread. Why is it doing this?
check to see if the needle is damaged
some sewing machines bunch up on the underside when the thread come off the thread take up lever
Sep 27, 2010 | Singer 3116 Simple
The sewing machine model is CE 5000PRW. The uppe...
It sounds as though the problem is with the tension in the bobbin. Check to make sure the thread is pulled through the tensioner on the bobbin case, if it is check and adjust the tension on the case.
May 21, 2010 | Sewing Machines
I bought a second hand Juki industrial machine , model DDL 5550-7, but struggle to get the tension of the stitches right. where do you set the lower stitches tension
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Jul 01, 2009 | Juki MO-644D Mechanical Sewing Machine
Singer CE-100 Embroidery thread bunches up underneath fabric
I had this problem and it all came down to using the wrong backing. I kep trying to use tearaway on everything but WRONG. Using the proper backing corrects most problems. Good Luck!
Oct 30, 2007 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
94 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
