Question about D-Link DI 514 Wireless Router (DI-514)
My D-Link Router was working OK for the last 3 years, I just removed the Cables to clean the work station and reconnected. (1) With proper connection Lights did not come -up in short no power to the router (2) There is power in the plug point (4) Did the hook-up as it was through the modem as befor Any idea? why the Router is not working?
  • 922 Answers
If you plug the AC adapter into a live AC outlet and the correct port on the router the power light should come on. If it does not either your AC adapter has failed or the router itself. You do not need to connect anything else for it to power on.
If AC power checks out then you need the replace the AC adapter or router.
Posted on Oct 12, 2010
My 124xmax year 2014 won't start starter switch completely dead but turning on the key all dash light are working
Long story short I will give you the hows and not the whys.
  1. Remove the positive and negative battery cables
  2. wire brush the posts on the battery and the inside of the cables untal they are silver all the way around
  3. reconnect and MAKE SURE THEY ARE TIGHT.
  4. If possible remove caps and add tap water(it's OK) till all cells are 1/2 inch. from the top replace caps.
  5. You may try a start. If not
  6. check batt volts should be 12 or more volts. red to pos back to neg on volt meter. no volt tester
  7. charge battery and try start. If not
  8. follow the batt cables to there ends and clean and tighten them, Try start. should be ok, if not get back to me and we will continue
MDS
Mar 28, 2016 | Cars & Trucks
HEAD IS MOVING... BUT NOTHING PRINT.
Step 1:
Clean headboard using IP. dry it properly.
Step 2:
Reconnect all the FFC connnections.
Dec 13, 2012 | Epson Stylus Pro 7800 InkJet Printer
I am having problems with my Linksys wireless router WRT54G connecting with the internet. When I connect the router to the internet I lose internet connections. Normally it works with the internet, but in...
1. RESET both the modem and router by unplugging them from the wall outlet for 30 seconds.
2. Power them ON again, and after 2 minutes check the connection.
3. If not OK, connect a computer directly to the modem, reset the modem and check the connection after 2 minutes.
4. If not OK, check your cables and if these are OK, call your ISP for your status and line quality.
5. IF OK, check the Powersupply of the router.
Sep 04, 2011 | Linksys Wireless-G WRT54G Router
Last january my d-link WBR-2310 still working fine but now i wanna use it, it wont connect in the net?
Try power cycling the router.
Disconnect the router from all computers. Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | Computers & Internet
Internet went out on the wireless router and it will only stay in local only
Hello
First check with your internet provider if any outages are reported in your area.
Next try a reboot of the router.
1 Pull all cables ot of router,including power.
2 Find reset button,usually in the back use a pen tip or paper clip to hol it in for 1 min.
3 Reconnect cables,power last. Then power up router.
4 Turn on pc.
May take a minute or two to find the internet again.
Jan 08, 2011 | Computers & Internet
550 NCOMPUTING PROBLEM
when i insert ncomputing cd in my computers drive and want to install ncomputing softwere the massege appearce that "NComputing vSpace not installed
Error report:
This software is hardware protected. Your hardware is not supported. Please contact NComputing Inc. or its partners to purchase supported hardware. plz solve my problem as soon as thank u
Jul 16, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
95lumina want start, want engine want rotate when trying to start, it just click. radio works, lights and all. it just want turn over. i changed the starter but still same problem
The Battery is not fully Charged or the Cable Connections to the Battery are corroded or oxidized.
The clicking is an indication of this. Yes you have a radio and lights and all; but there is not enough power reaching the Starter to make it work.
A good way to prove this is to get a jump start. With a good solid connection of the jumper cables, the car should start.
Remove the Wire Cables to the Battery.
Use a Battery Cleaning Brush ($2) at most stores. Brush the inside holes of the Cable connections. Brush the Battery Post. Shiny metal is what you should see. Reconnect the Cables to the Battery Make sure they are tightened properly.
At Walmart/KMart or even Harbor Freight they have Volt Meters for around $5-$10. Take a measurement of your Battery. Anything less than 11 Volts will not Start the car.
Today's Batteries only last 3 to 5 years. When was the last new battery you purchased for this car?
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 07, 2010 | 1995 Chevrolet Lumina
Just got off the phone with internet service and they are not the problem... when i reconnect the cord back into the router i loose internet access- whats wrong?
If you loose your internet connection when you connect the modem to the router and are OK when it is directly connected to the modem then your router sounds like it had died.
Some times routers that have been hard booted too many times die a short death or some manufacturers routers only last 1-2 years like D-Link,Netgear & Belkin
Jul 01, 2009 | Computers & Internet
My linksys router will not connect to the internet
Reset your rourter, with a pin or a paper clip for 30 seconds and disconnect power and wait for 30 seconds and reconnect it back and check if the power light is lit up in your router first..if yes, connect the modem cable out to the wan port of your router, and check if the wan light is lit up in your router, if yes connect a lan cable from the number 1 lan port of the router to the desktop pc and check if the lan 1 light is light up if yes the router is working properly, then check for the ipaddress in your desktop..if not your router might have gone bad..if you have any doubts rever back..
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
D-Link DI 514 Wireless Router (DI-514) Logo
199 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
