Question about CADAC Grilling
Cadac carri chef
I have recently purchased a second-hand Carri-chef but the connector that screws on to the control button and fixes to the gas pipe is missing.Any idea where I can get one?Thanks!
  • Ronaddo Jun 02, 2008
    I live in the West Midlands,Close to Wolverhampton
Hi Ronaddo, where are you living?
Posted on Jun 02, 2008
My cadac is burning black smoke
Check the venturi tube just behind the control knob and before the burner tube. You will probably find it full of spiders nests. You need to introduce air to the gas and that is where it is regulated.
Jun 04, 2016 | CADAC Safari Chef 6531 Grill
Can i convert my cadac safari chef from hp to lp
Vinnie, first lets take a look at what HP gas is, as opposed to regular LP Gas.
HP Gas is a Propane / Butane mixture liquefied under normal ambient temperature and moderate pressures. It is a safe, clean burning, reliable, high calrofic value fuel. In addition to it use as a domestic fuel, it is also widely used in industries, where there is a requirement of low sulphur content fuel and fine temperature controls. HP Gas conforms to IS:4576-1999 specifications.
Converting your grill to HP Gas may be possible, but there would need to be some adjustments to the burner's venturi valve. As the air to gas mixture may be different. Also, you would need to check with your HP Gas Provider, to see if a different pressure regulator would be necessary.
Hope this helps you and Happy Grilling!!.
Jun 27, 2011 | CADAC Safari Chef Portable Grill
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
Cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
I need an instruction booklet in order to sell a Cadac Carri Chef
go to there homepage and find files and download it disc usually it s an adobe file and burn from there
Aug 10, 2009 | CADAC Grilling
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as...
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Jul 01, 2009 | Grilling
Were do the parts go on the cadac bbq
hi i need a new gas igniter for my carrie chef, can you tell me where i can buy one
Jun 15, 2009 | CADAC Safari Chef Portable Grill
Cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
Grilling Logo
315 people viewed this question
Top CADAC Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
