Question about Sharp AR-M280N Copier
Can't get copier scanner to scan to PC desktop folder
    Guru:
  • 452 Answers
You should install the driver of the scanner to get it in your desktop
Posted on Oct 12, 2010
Since upgrading to windows 10 I am unable to scan. Message Is Unable to write the file to this folder. Please make sure you have correct permissions to write to this folder. (CC3-107-00431005)
That sub folder is in a windows protected folder. See if you can create a folder un your libraries subdirectory and name is scanned docs. Then tell the scanner to send it to that folder
Aug 12, 2015 | Brother MFC-7420 Laser Multifunction...
When I try to scan from my new Ricoh SP 250 to either email or desktop folder I get the following error message: "Server Response Error"
Have you setup mail server on copier as for desktop did you setup a share folder on computer. Have you gone in create a user with email info and scan folder path and Both might need to be authentication . Go to ricoh-usa.com/download and in search area enter model and click on manuals will explain setup for this.
Oct 13, 2014 | Ricoh Aficio SP C210SF Multifunction...
Why am I getting the message "the system cannot find the path specified" when trying to scan?
Hi Tania,
You receive this notice when the drive and folder the scanner is configured to save the scan is missing. You can correct this by telling the computer where to save the scan. follow this simple steps.
  • On your computer desktop, click Start - open Devices and Printers -
  • Right-click on the printer/ scanner icon and select scan options. Assign a destination folder for saving your new scans.
Please rate me if this helps.
Oct 08, 2014 | Canon PIXMA MX452 Wireless Inkjet...
How do you scan to desk top pc
Go online and download software direct from scanner manufacturer, this would allow u to create a desktop icon to facilitate scanning to your folders or email addresss
Oct 17, 2013 | Dell Office Equipment & Supplies
How to scan using an imac
  • Connect a USB or FireWire scanner to the iMac using the scanner cord and the ports on the back of the iMac. Turn the scanner on.
  • Use the CD or DVD that came with the scanner to install any required software drivers. If the manufacturer's instructions indicate the scanner does not require additional drivers, you can skip this step.
  • Put the object you want to scan face-down on the bed of the scanner.
  • Scan the object by pressing the "Scan" button on the scanner. Image Capture will launch automatically and display a low-resolution preview scan.
  • Set up the scan using Image Capture. The settings available will vary depending on the scanner you are using. With most scanners, you can select a specific area of the object to scan, choose a scan profile based on the type of object you are scanning, adjust the color options and set the resolution.
  • Click the "Scan" or "Scan to Folder" button to scan the object. The image will save to the "Pictures" of your home directory if you press "Scan." The image will save to whatever folder you specify if you press "Scan to Folder."
  • Oct 25, 2010 | Computers & Internet
    How can i hook up the scanner?
    Hook the network cable to your scanner nec card on the machines, note that this machine has two nec cards, one for printer and one for scanner.
    after that Go to the setting and under setting/Scanner Default create and ip address for the scanner. after you done from that go to the computer browser, type in the ip address, you can choose scan to smb or pc.
    Scan to smb needs shard folder but scan to pc needs to run software on your computer on your pc.
    Setup the sender list which you need to fill only the ip address of the machine as sender.
    Go to destination setup the ip address of the computer you scanning to, the path is the shared folder name, and the user name and password of your computer and you good to go.
    To make it easy for you, Provide me your email and i will attach the scanning manual to help you setup it correctly and you can always get back to me in any question.
    Best Regards
    Kyocer/copystar Expert
    Jul 13, 2010 | Kyocera Copystar 221 Black and White...
    I have a kyocera cs-1650 and am trying to scan to pc. I have scanner file utility installed, yet it shows no connected scanners in the status box. How do I get scanner file utility to recognize and...
    You have to make a folder on you computer to scan to. you have to configure the scanner file utility with the path to that folder. You have to setup the scanner NIC with a sender ans a destination. The destination has to point to the PC running the scnner file utility by inputting the computer hostname or IP. The scanner nic can be configured with your web browser by putting the scanner NIC IP in the address bar. You have to make sure your firewall is not blocking the file scanner utillity. For more help go to www.gfbm.net.
    Dec 31, 2009 | Kyocera Copystar CS-1820 Black and White...
    How to Link Scanner from ricoh aficio 1232c
    Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
    Oct 18, 2009 | Ricoh Aficio 1232C Color Copier
    Ricoh MP4000B
    hi
    a rijas working in dubai
    my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
    Feb 18, 2009 | Office Equipment & Supplies
    Help with scanning on mour Ricoh Aficia 2035.
    Since this is a  network printer, you can scan to folder,FTP site or email. alot will depend on your network enviroment. SMB is the simplest. The folder you are scanning to need permission to write to the folder. If you have email you need to enter your smtp server IP address in the user tools and an senders email address. the manuals with the copier will help or download them.
    Oct 12, 2007 | Office Equipment & Supplies
    Sharp AR-M280N Copier Logo
    75 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
