Question about Sony Giga Vault RH-K80U2 80 GB Hard Drive
Replaced hard drive in nas-s55hde but now need boot software, can any one help
Unable to download the Seagate Central NAS 1D driver on my Windows Vista desktop....help?
I think you mean hard drive. NAS devices aren't meant to be plugged into computers. They're meant for networks. NAS means "Network Attached Storage". There should be a disc that comes along with it to set it up. If you don't have one, you can connect to it through a web browser to set it up, thats usually how its done. If you look at the devices in your network, you should find its name, and then you can type in its name in a browser. As an example, if its name is seagate-nas, then you type "seagate-nas\" (without the quotes, and with the '\') into your browser and it should come up
Jan 12, 2015 | Seagate Central 3TB Personal Cloud Storage...
How to recover password from LaCie 1TB Rikiki USB 3.0 Portable Hard Drive
ga naar lacie.com and probeer
Support & Downloads
Frequently Asked Questions pfp.gif Printer Friendly
Configure Your Drive Using the NAS Administration Page
Accessing The NAS Administration Page
    There are two ways of accessing the NAS Administration page, Using the IP Configurator Wizard, and Using the Browser.Using the IP Configurator Wizard
May 04, 2014 | LaCie 2big Quadra 3 TB Spare Drive3 TB...
Iomega mdhd 360 n
The following may help:
You can either use the management software: Iomega Discovery Tool Home : Read First
or
Instructions to Direct Connect to NAS:
Unplug the NAS from the router
Unplug the pc from the router (if the pc is wireless, disable wireless)
Using Ethernet Cable, plug the NAS directly into the pc with no other devices attached.
Restart the NAS and wait for it to boot COMPLETELY 100%
The NAS will request an address from the PC which will be an APIPA address (this is a 169. address)
Open up your Start Menu and type in CMD in the search bar and select the CMD program.
Type in "arp -a" in the cmd prompt
The first time you use the arp -a in a cmd prompt, it gives you the 169.x.x.x address of "The PC"
You may have to arp -a twice to get the NAS address.
The second time you use the arp -a I will get another APIPA address in the 169.x.x.x address
Take the new address and use it in the web browser just like normal to access the device
Mar 22, 2014 | Computers & Internet
Seaget BlackArmor NAS 110 not booting
Sounds like a software problem with your BlackArmor or perhaps a failing drive. You might contact a low cost data recovery service such as http://FreeDataRecovery.us
They perform online data recovery over the internet and also offer do-it-yourself data recovery advice.
Oct 10, 2012 | Seagate BlackArmor NAS 110...
I FORMAT MY HARD DISK BY MISTAKE SO NEED AGAIN WD SYNC SOFTWARE
that is a easy one my friend here is the link to download the new software from Western Digital.
http://www.wdc.com/wdproducts/wdsmartwareupdate/NAS.asp
Jan 23, 2011 | Western Digital My Passport Essential...
My Belkin Home Base F5L049 isn't recognising my external hard drives that have their own power supply. Seems to be working fine with USB powered hard drives. How do I get it to recognise my powered...
I am having similar problems with my HomeBase. I have 3 x 1Tb Seagate external USB2.0 NTFS drives (FreeAgent) connected. The aim is to have my digital TV, LG set-top box, Apple TV, PC and Laptop all access the files and capacity offered by the NAS option.
They work fine in 'single user network USB' mode, but are very flaky / non-existant in 'NAS, multi-user' mode. There are times when the HomeBase is restarted and recognises one or more of the drives in NAS mode, but mostly they are not recognised. On the back of the unit, you can see the LED next to the USB port leading to the drives initially stay lit, but then flashes for 10-15 seconds and then goes out.
As I want the hard disks available to multiple devices I need to use the NAS setting.
Did you try to set the drives into 'Network USB mode' rather than NAS mode. Does that help?
Did anyone have a solution to the problem? Unfortunately Belkin technical support have not been very useful yet...
Thanks
Mark
Dec 26, 2010 | Belkin Home Base WirelessN Access Point...
Good morning. I have installed in my Company a Iomega nas model 450R. This morning after a reboot,it seems it can't find the boot disk and the nas asks for a operating system restore or go back to factory...
It seems that the main hard drive in this server either went bad, had a windows corruption or that one of the internal connections inside this server went bad.
You would need to check on all three of these areas to make sure 1) the main hard drive is functional (which is my first suspision so check the hard drive for errors and if it fails you would need to do a data transfer to a new hard drive). 2) use your windows software to repair the dammaged registry that may have been corrupted somehow (only do this if the main server's hard drive passes its hardware tests).
You would need to run the original os but I would need to know which one you are using to guide you more to solving the regisrty issue.
3) Hopefully tis server has a warrenty and it may need replacing if all else is working.
Try #1 which is the highest supected for failed hard drive issue (remember if discovered that main hd is bad you may need to perform a data transfer immediatly and replace with a new hard drive.
any other questions please write back with status :)
Mar 19, 2010 | IOGear Computers & Internet
Reading T4 Device
Did you try to boot the system without all the harddisks inside (keep at least one).
This helped me to bring up the NAS-T4 up again.
Mar 04, 2008 | Fastora NAS-T4 Hard Drive Array
My Nas Fastora T4
There's a 9-pin serial connection on the back, can you use that connection to a terminal to see anything? Also, if you don't have access to the manual, visit this link to download the manuals: http://www.fastora.com/product_index.php?doc_name=nas-t4
Oct 22, 2006 | Fastora NAS-T4 Hard Drive Array
Sony Giga Vault RH-K80U2 80 GB Hard Drive Logo
78 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
