Question about Ebac AD850 Dehumidifier
Ebac 880 E
My defrost system is not working,
ice dont melt!
what can i do?
thanks
  • from belgium Jun 02, 2008
    hello,
    thanks for your help,
    but my model have e "frost guard"(ebac 880 E)
    end my humidity is 75%
    normaly its working automatily
    but now no more, i think i have e defoult.
    i dont now if a can fix it?
    (sory for my englis!)
    thank you!
  • 525 Answers
The following statement is a parameter for all dehumidifiers and some of the control issues may vary, but the theory is the same.
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
If your model does not employ a "Frost-Guard" the condition you describe will avail itself when the above parameters are not met.
Simply unplug, or turn off the unit, until the above parameters are met or exceeded.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • David Emmel
    David Emmel Jun 02, 2008
    Great hearing from you, my family comes from Belgium so I can understand well what you are saying.
    Since your humidity is in the proper range, and I can assume that the temperature is also, then you may have a faulty frost guard or a pressure problem in the sealed system. Unusual, but not rare. If you have a warranty on the unit, I would exercise your right to get it fixed or replaced.
    Dave Emmel (Illeagle)
I have a Ebac Homedry 660 dehumidifier. How can I tell if the demidifier is defrosting?
If it was frozen and is now thawing, you will probably find some water in the collection container and some on the floor.
Mar 09, 2011 | Ebac HD880 Dehumidifier
My 880 home dry is around 15 years old now and when on makes a loud squeaking noise, what is it and is it worth repairing , other wise works fine .regards
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
Nov 28, 2010 | Ebac HD880 Dehumidifier
Where can I get a Ebac Dehumidifier filter replacements in New Zealand ?
If your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Noel
noel.bee@xtra.co.nz
Jul 09, 2010 | Ebac HD880 Dehumidifier
I HAVE A EBAC HOMEDRY 880 dehumidifier LOOKING FOR A FAN MOTOR THE MOTOR AT PRESENT IS A MAGNETEK UNIVEARSAL ELECTRI LTD 220/240VOLT 50HZ 0.16A impedance protected
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Mar 20, 2010 | Ebac HD880 Dehumidifier
Replacement fan motor for ebac homedry 880 dehumidifier. fan motor Mod No aa2c6235
Noel
Feb 27, 2010 | Ebac HD880 Dehumidifier
Ebac 2850 made rumbling noises and shook now not working at all
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 01, 2010 | Ebac Dehumidifiers
Capacitor melted on Ebac 600 where can I get replacement
google your full model number - take out bucket and look in cavity for sticker
Dec 31, 2009 | Ebac HD880 Dehumidifier
Ebac xl Dehumidifier not collecting water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 11, 2009 | Ebac CS60 Dehumidifier Dehumidifier
User instruction
Here is the link for the Owner's Manual off the Ebac website:
http://www.ebacusa.com/technical/Manuals/HD.pdf
Jun 30, 2008 | Ebac HD880 Dehumidifier
No instructions
only two fan speed - fast or slows. use fast humidity - cuts out appliance when required humidity is reached. set it about half way note that is f bucket if full, then a float switch will cut out the appliance
May 21, 2007 | Ebac HD880 Dehumidifier
Ebac AD850 Dehumidifier Logo
551 people viewed this question
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
NOEL
NOEL
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
