Question about Vizio P50HDTV20A 50 in. Plasma HDTV
I have a Vizio P50HDTV20A. I came back from a comercial break to discover a black screen with sound. Checked all cord connections, unplugged cable until tv was cool to touch. Still same problem, sound but has a black screen. Diagnosis and prognosis please?
    Scholar:
  • 143 Answers
My guess from this little information is the buffer boards are bad. The Y Buffers... (3 boards, main, lower, and upper should be checked). The main buffer could just be out, but usually when we replace one, we replace all three. If you are tech savvy and are going to try to fix this yourself, I would start there. Here is a pic of the Y main.. Part # LJ92-01399A . I have a Vizio P50HDTV20A. I came back from a - 086lj9201399a.jpgthe Y lower and Y upper are connected to this.. Usually on the left side of the TV (from the back).
There is a fuse on this board, so it could have blown, but more likely, it's time to be replaced.
The Upper and Lower Y Buffers are part #'s LJ41-05121A and LJ41-05122A. I recently replaced mine on my Philips Plasma and it's been working fine since!
Good Luck!
Posted on Oct 12, 2010
Testimonial: "I'm a techno but this gives me somethin for repairman. now to start to find him in my little town of 3200!"
Sound but no picture
this happened to me about a week ago. It was my cable box. If you have a cable box,unplug it from the electrical socket Wait about 30 seconds and plug it back in. give the box time to gather all info and then retry the tv.
Jan 21, 2014 | Vizio P50HDTV20A 50 in. Plasma HDTV
No sound, no picture
Hello sorry to hear that. From your description it sounds like your signal board may have been damaged by you plugging in your laptop to it. The signal board is the one with the tuner on it.
Feb 22, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
The power appears to come on, but no picture and no sound
Look at power board. check fuses on board and replace fuses with new ones.
Hope that helps.
Dec 22, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have power and sound but the screen is black ... i have read that it could be a fuse ... how do i access the fuses or where are they located on the tv ... it is a vizio 50 inch plasma P50HDTV20A
Hi the picture on a plasma TV is controlled by the Zustain board. You have a bad Zustain board. Their are two on your TV so you have to figure out which one is bad to order it. Most of the TV the bad one will have a bad fuse or it will not heat up like the otherone. You can always replace them both also. you can get parts fro this TV at www.interliquidparts.com
Jun 13, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Turned the tv off few hours ago and came back and now it wont turn on - checked all connections - still no power - can not turn on from remote or on side of tv.
Check the power outlet source?Yes,tries tv unplug,replug tv back like about an hour later,by letting the tv resetting itself back to the factory setting.The tv now should be working again.Not than the tv have power supply board problems and causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 05, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a 50 inch plasma vizio tv. I was watching it then i heard a pop the screen went black and i still had sounds yesterday but today no sound, I called vizio tech support they told me it was the gas...
when you here a loud pop its usually the sustainer boards. Have you checked the fuses on the sustainer boards first to see if they are still good. There is a IC chip under the heatsink and when it gets extremely hot it gives. Also check you power supply board to make sure you don't see any swollen capacitors, leaky or bulged out from the top. Let me know if that helps at all.
Oct 26, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
My vizio plasma tv quit, Problem with the
Check ur power source with other devices?Yes.Than,the power supply board it dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 23, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio p50hdtv20a with no picture or sound
sounds like tv shop knows that is missing because they removed it so as not to work when custermer got it back with no charge
Jun 06, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Oct 17, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
1,232 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
