Question about Honeywell Heating & Cooling
Can I get a manual for a honeywell programmable thermostat 97-4730?
Buffalo12980
  • 625 Answers
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
SOURCE: Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Posted on Nov 25, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
co7196
  • 3433 Answers
SOURCE: unlock Honeywell TB7220U1004 Ultrastat Commercial
Pull off face and remove batteries and reinsert.
Posted on Jun 01, 2009
SOURCE: I am renting a townhome and cannot reprogram the
That is actually not the model number. That's some sort of a code on the flip-up panel with the programming instructions, right? You have to remove the thermostat from the plate that holds it to the wall and look on the back to find the actual model number. Yours is probably model CT3200. If so here is a link to the owner's manual on the Honeywell web site:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Posted on May 22, 2010
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Manual honeywell programmable thermostat
Follow the below link, select thermostat on the upper box, then type CT3600 on the lower box.
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Oct 09, 2012 | Honeywell CT3600 7 Day Electronic...
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
Cant take off cover to replace battery from my honywell thermostat
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 26, 2010 | Honeywell Programmable Thermostat Heater
Can i use th5320u1001 on 2 stage compressor and 1 stage heat? tom roll , abe service company , bowling green,ky
Yes, that t-stat has that capability...
http://www.pexsupply.com/Honeywell-TH5320U1001-The-FocusPRO-Non-Programmable-Digital-Thermostat-Premier-White-4956000-p
If you need the manual to get it set up then check out this tip...
heatman101
Sep 15, 2010 | Honeywell Electronic Programmable...
My Honeywell Programmable Thermostat RTH2410 operates intermittently, the entire unit , display and all, turns on and off at various times throughout the day.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You need to reset the t-stat and totally reprogram it...
Look in your manual how to do that or...
heatman101
Sep 13, 2010 | Honeywell Focus 6300B 5-2 Days...
How do I open the Honeywell programmable thermostat Model CT3400? I've never done it before and don't know how to open it.
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page.
Oct 04, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
199 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
