Question about KitchenAid KSRS25IL Side by Side Refrigerator
Ksrs25q stopped freezing and cooling. i took off back panel and fan is running. i hear a click from left of compressor and then 30 seconds later it click off. i already cleaned coils. any ideas. maybe relay/starter switch?
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: kitchenaid compressor starts then hear a click and it stops
most likely you have a bad start relay on the compressor. when looking at comp on the left side you will see a little square relay with 2-3 wires going to it. the pt# you need is 8201786 and can be purhased online or at a local appliance parts house this is an easy repair and the part should cost you less than 70 dollars. thx peyton
Posted on Jan 28, 2009
  • 52 Answers
SOURCE: Unit stopped cooling and freezing & have recurring clicking noise
sounds like compressor motor is gone ...call tech
Posted on Jul 26, 2009
mrbobfixit
  • 259 Answers
SOURCE: Startelay switch on Kitchenaid side-by-side
Yes the relay and overload will come with the new compressor.
Posted on Jun 12, 2010
handynick
  • 93 Answers
SOURCE: coils in freezer constantly freezing
Sounds like you have a defective unit. If still under warranty take it back.
Posted on Jul 09, 2011
Not freezing or cooling and compressor clicking on and off
From your description it sounds like the start components (start relay, overload and capacitor) are having problems. The clicking you hear is probably the overload kicking out to protect the compressor. It is quite possible that the compressor simply has gotten too hot and after sitting a while will restart when plugged back in. The start components are not generally considered 'user serviceable' parts. When the compressor has cooled to pretty much room temp, plug it in and be listening for those clicks. If you hear them, unplug it because it could eventually damage the compressor. Those components give the compressor an extra jolt to get the compressor running then they drop out of the circuit. If the compressor doesn't start, it creates heat until the overload drops out.
Mar 29, 2014 | Maytag MZD2766GES Side by Side...
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
My hoover hfa29k fridge freezer originally started to freeze the contents of the fridge and appeared to be running continuously.I unplugged it and left it for about an hour and then switched it back on...
4. Wait one hour.
Try this and let me know.
Feb 22, 2011 | Hoover HFA290K Bottom Freezer Refrigerator
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Side by side not working
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Frigidaire side by side
The compressor sounds like the start device went bad. When that happens there is the "click" during trying to start, but since it can't the compressor overheats in time and then the thermal overload opens to protect it from overheating. Take the back lower panel off the refer and see if the compressor is really hot to the touch. If you have a little white colored box on the left side of the compressor pull it off and shake it... if it rattles and debris falls out you know it's bad. There is a kit that replaces it and it's real easy to install yourself. If you have a compressor that has a little blue indian head symbol on it however... your compressor is toast. Once they overheat they're done. If you have any other brand name you should be OK with a simple start device change out.
Jan 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
59 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
