Question about Bose Wave Radio
Wave radio display
All Led dispay lights are lighting up and staying lit all the time.
  • 1 more comment
  • rmenzies Feb 05, 2009
    Radio and remote work fine but all segments in the display are lit up all the time
  • nglassma Mar 02, 2009
    I was listening to the radio yesterday (FM) when it suddenly shut off. Then the clock screen showed "1:" until this morning. I unplugged and replugged it from the wall outlet. Same problem.
    This monring I changed the 9V battery. Now all the lights turn on and stay lit. It doesn't respond to any buttons or the remote. Any idea how to fix it?
  • PANDECON2 Mar 07, 2009
    ALL ITEMS ON THE DISPLAY ARE ON AND NOTHING WORKS
5 Suggested Answers
SOURCE: bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Posted on May 14, 2008
  • 3 Answers
SOURCE: bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Posted on Oct 06, 2008
SOURCE: blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Posted on Jan 02, 2009
SOURCE: My Bose Wave Radio, Model AWR1-1W, has no sound
I found a solution on a similar problem saying the audio amp IC is damaged. You will probably need to replace this. Unfortunately I don't know which IC it is.
Posted on Apr 30, 2009
Clock display stays lit
yes on some cars this is normal, the amount of current that the clock draws is very minimal and should not cause problems with a battery. Unless not used for very long periods
Jul 09, 2012 | 1995 Buick Skylark
I have an original Bose Wave radio. The clock digits now do not brighten during the daylight hours or when a light is turned at night, as they used to. If I look very closely, the digits are lit, but...
If you look closely you will find a light sensor on the outside - it looks round and has some squiggly red waves on it. It's probably bad and needs to be replaced. Its' purpose is to sense the ambient light, send a signal to the processor and vary the brightness of the display. Check also to see if it's blocked.
Feb 19, 2011 | Bose Wave Radio
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
29 LTD CB Radio: Calibrate cb radio...
The CAL is to calibrate meter for reading SWR (standing wave ratio) which is reflected power when transmitting back to receiver(radio) from antenna system.
This CAL switch position when selected and mic keyed uses the CAL knob to align the meter needle with inverted red triangle next to cal on meter. Then when you select SWR switch position meter will display accurately when mic is keyed for that channel. Now notice the difference when you go between channels 1 and 40. The ant led light will act as idiot light if it is not lit then you are most likely safe to transmit.
I say system because your vehicle, antenna and coaxial cable are all part of this system. When you have a high reading and have to trim you antenna this is really calibrating the antenna to the vehicles body which acts as a ground plane.
May 16, 2010 | Cobra 29 LTD CB Radio
Every light on my bose wave radio is lit up. How can I reset it
Contact Bose at Bose.com. They will have you send it in for repair.
Aug 28, 2009 | Bose Wave Radio
Attenuator light always on... no sound
That light that stays on is not for the "ATT", it is just an indication that the unit has power. The problem with your radio is most likely the power amp IC inside the radio if you are using speakers connected directly to the radio from the speaker wires on the harness. If you are using an external amplifier for your speakers the problem will be either the electronic volume control IC or a muting transistor that has gone bad or the external amplifier is defective. There is no way to know exactly what is wrong without doing a few checks on the radio with a multimeter on have the radio on a work bench to be able to open it up and check a couple of things inside of it.
If you have a multimeter and a power supply (to turn the radio on while on a work bench) I can guide you thru the troubleshooting process to help you figure it out. But you will also need to have a soldering iron, solder, and solder wick to be able to remove the bad part and put in a new part.
Let me know if you will require any more help from me.
Dave
Oct 19, 2008 | Kenwood KDC-MP7028 CD Player
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Feb 25, 2007 | Bose Wave Radio
Bose Wave Radio Logo
216 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
