Question about Cell Phones
Had this phone for many years, love it. couple of days ago it started to have a fuzzy noise but i was getting a dial tone. it will not dial out from the handset but it will dial out and connect from the base. I can make a call from my landline in another room then pickup on the uniden handset but the sound is very poor. I have replaced the battery and let it charge for about 15 hours, but this didnt help. are replacements for this model available. Thanks
  • 921 Answers
If it only works in the base then it can be said that it only works when plugged into which means it has a battery problem. Rechargeble batteries expire after 1-5 years depending on their application and usage. I recommend that you replace the battery in the handset.
Posted on Oct 12, 2010
HP Officejet 6500 no longer hears the dialtone. The line works fine with a regular phone, but not the printer. Up until a couple of days ago, it worked fine. The printer says the line is in use (wh
Usually on hook telephone line voltage around 40V DC +/- depends on exchange, voltage will drops below 12VDC if its half hook..You will get engage tone/usage tone if voltage drops less than 12V, in this condition you wont get any incoming calls.
You need to open the printer formatter to locate the modem where telephone line inserted..
Let understand why this malfunction happens..
The ring voltage between the line is +120V AC, but it should not exceed more than 200V.. To protect the circuit, line will guarded by component called "VARISTOR". The Varistor will burns if voltage reaches specified or more voltage across it.. Once varistor burns U will get engage tone always... Basic multimeter is enough to check the varistor, put multimeter in diode mode, test both ends of varistor, it should not show zero value or beeping. Some times it may burn, blast or bulge. Remove the faulty component from the circuit with the help of soldering iron, connect the line & verify, if line is good replace with same rating of component.. Chk for the ring & dial tone...
Req tools: Multimeeter, soldering iron, little paste & Led, screw driver set for opening the printer..
Depends on design varistor may fix accordingly which we need to find out the location.. But its always fixed between line in path. pl see the attached sample diagram.
if you are non technical pl don,t try it...Best of luck.. 6f4a7950-5cc9-42c6-bb47-b2ba2007add0.jpg 21aa8d50-de72-49d9-a692-6c813c2c0768.jpgEx: Varistor ac224650-2c77-4de1-934f-929cbd6f0d15.jpg Damaged/burnt varistor
Apr 01, 2014 | HP Officejet 6500A Plus Wireless...
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Apr 10, 2012 | Panasonic Lands Phones
Panasonic phone KX-TG4500 base not turning on, I have had it for 3 years and all of a sudden it died, like a battery goes off.
I could tell the base unit was about to go a few days ago. Have had the phone for years with intermittent problems but it has been for quite awhile now. However, the screen on the unit started to blink a bit a few days ago. Had a feeling it was about to go but the phone kept working until this morning when it suddenly dies. After reading that changeing the cord might work, I replace the unit power cord with one from my handset and the phone is working again! Thanks for the suggestion!
Oct 01, 2009 | Panasonic KX-TG4500 Phone
I cannot answer calls - the base has the message "answer off"
The phone apparently fixed itself. After not working correctly for a couple of days, this morning it was functioning like it was 3 days ago. I get a dial tone, and the caller ID works. I have no idea why.
Sep 04, 2009 | Uniden Cordless Phone
No dial tone in home. I have checked the cords
unplug all phones and cords check each phoneindividually until u find the phone causing the problem, i had this problem a couple years ago and came to be one of the cord plugs..good luck..floyd
Jul 24, 2009 | Panasonic KX-TG2357 Cordless Phone
Ricoh 1013F no dial tone
On the back of the copier, look to see if you have two phone jack inputs. Did you try both of them. One is for a handset & the other is for the phone line....
Feb 26, 2009 | Ricoh Aficio 1013F Copier
My VTech 2461 cordless phone is stuck on Pulse
To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
Dec 17, 2008 | Vtech VT 2461 Cordless Phone
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
