Question about Nokia 3110 Cellular Phone
Sir i used *#7780# and also *#7370# bt my phone was not formatting..pls give some suggesion what should i do? can we formate it with nokia pc suite
  • 10,421 Answers
Actualy i want to format my 3110c mobile phone memory but i can't.please give me solution
Normally Nokia and other symbian devices can be reset with *#7780# or *#7370#. if not you should find master reset in the general settings.
Feb 03, 2011 | Cell Phones
My handset modelno.6070 is locked.pls give his secuirty code
Hi hsrivastav...
You can unlock by 2 methods 1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you have a nice day...............:)
Feb 02, 2011 | Cell Phones
Hello sr, gm i hv the problem with my nokia 3110 classic, when i connect my phone to computer then this message is show " Pc suite does not support the connected phone.Pc Suite settings file is...
hey i was also having the same problem with my mobile
when i connect to pc it gives the same error mentioned above because of this my mobile is not able to connect with the internet.
then i found that this can be solve with formatting and i follow the formatting tutorial it solved my problem
go to below link and follow the instruction to format mobile
http://www.fixya.com/support/r5875102-format_nokia_mobile_phones_3110c_2700c
Nov 14, 2010 | Nokia 3110 Cellular Phone
Why my nokia e71 can't view message?. but can send and get a message.. but i can't view it when my friends reply my message..
Sir,
You need to format your memory card and thats hould fix the issue.But backup all your contents before
formatting the card.
1.Take out your memory card and connect it to your computer by using some card reader.
2.Copy all the material you want to your PC using PC suite,then format it completely.
3.Inert the card back into your phone.Restore the copied material later. And it should work again.
This error is most probably related to the memory card itself. You just have to format it. It happened
with me few months back, I formatted my card from phone itself and used PC Suite for backup etc.
and since then its working fine.
Nov 04, 2010 | Nokia E71 Smartphone
I forgot the password of micro sd card
better u download elock or ilock software from net in jar format..use tat software and lock ur folder
Jul 03, 2009 | Nokia 6233 Cellular Phone
I have nokia 5310. i cannot remove my password of memory card because i have forgot it. i have no idea about password.so it cannot be remove so please give me a solution
copy ur datas in th card to ur pc using th nokia pc suite an format ur memory card by selecting th format option n th memory card option... kindly rate me.... thank you....
Jul 01, 2009 | Nokia 6233 Cellular Phone
Nokia hanking
*#7670# -- This is the Code for default Factory Settings
*#7370# -- This is the Code to Format the Phone
Note - All the data will loose(Ex. SMS Phonebook) if you use second one
thank you
Apr 14, 2008 | Nokia N70 Cellular Phone
How to download the pc suite for my cell phone
pls give me the w7ooi pc suite software my mail address thank sir
Dec 17, 2007 | Sony Ericsson W700i Cellular Phone
FORMATTING the LG KU250
Hi, I have an LG KU250 but my pc cant detect my phone even the LG PC Suite cant what i should do?pls help me pls pls pls
Dec 08, 2007 | Nokia 1100
My nokia needs to reprogram HELP plzzzzzzz!
*#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
Aug 17, 2007 | Nokia 6288 Cellular Phone
Nokia 3110 Cellular Phone Logo
82 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
