Question about Homelite Garden
Homelite blower/vac 33cc. how meny turns from full closed do you turn L adjustment , an H adjustment counterclockwise. after working on carburater. s/n ag o411524. ut 08932, 4hcps0304ab. 200mph
  • 3,083 Answers
I couldn't find anything about how to adjust the special H-head, but I did read that Homelite doesn't offer any advice on adjusting it, and requires that the unit be sent in for servicing,
I would take it in to a local small appliance repair place and see that they say- they may have delt with this problem before, and be able to tell you, or perhaps they will be able to do it for you.
Wish I had something more specific, but it sounds like they really don't want people adjusting it on their own.
Good luck, and hope this helps.
Posted on Oct 12, 2010
I have the MightyLite 26bv....will only run at half choke. When turn knob to run, it dies. Does not reach full power ever.
The parts inside the carburetor need to be replaced (gasket and diaphragm kit) and/or the L and H screws need to be adjusted on the carb. Try grasping and turning the L mixture screw on the carburetor (one closest to engine) about 1/8 to 1/4 of a turn counterclockwise.
Jul 01, 2011 | Homelite Consumer Products MightyLite...
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
Give it gas slows down
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 20, 2009 | Homelite Consumer Products Backpack...
My homelite leaf blower UT # UT08023B is running badly all of a sudden. when i pull the trigger to get it to full speed, it acts like it doesn't want to get to full speed only about half speed and it seems...
Its a fuel delivery problem. Its running lean.
Check the fuel line in the tank to see if the filter fell off. If the filter is loose in the tank than the best way to repair is to replace the fuel line. Also the diaghrams in the carb are dry or the screen is clogged. Lastly, if the fuel lines are not rotted and the screen in the carb is clear and everything is in proper working order then you can adjust the carb ( if it has adjustments). Start by turning the low speed needle out ( counterclockwise) 1/2 turn.
Nov 20, 2009 | Homelite Garden
Power up and down not consitant
1) spark plug
Chain Saws:
Remove Carburetor
Nov 12, 2009 | Homelite Consumer Products Backpack...
Just started bogging down when I try to give it gas.
1) spark plug
5) carburetor gaskets/diaphragms
Nov 09, 2009 | Homelite Consumer Products Backpack...
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Homelite Leaf Vac Attack
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
Carburetor adjustment for Homelite 2 cycle engine The product doesn't start easy, and it does come to full throttle. If I run it on partial choke it runs fairly good, but it has been getting worse. Last...
I have the same problem with my MightyLite 26cc Blower/Vac. If it does start it runs rough on full choke and stalls on 1/2 choke or run. I've tried everything, fresh fuel, Seafoam, etc. Nothing works. First time I used it the exhaust burned a hole in my brand new Carhartt hooded sweatshirt. Best solution, throw it away, never buy another Homelite product and tell anyone who will listen what a piece of junk Homelite products are.
Sep 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Getting the right tool to adjust carb on Homelite Blower.
Type in "AYP" on google...scroll down to "jackssmallengines.com, in the AYP part number box type number 530035560.
May 06, 2009 | Homelite Consumer Products Backpack...
Garden Logo
55 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
