Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
How do i set my " NAT" type to open for gaming?
  • nomportz Oct 12, 2010
    thanks for the quick reply. But when i first log into XBOX LIVE it tells me in bold letters with explanation point that my NAT type is not set to open and will slow down performance and limit the number and kind of games i can join
  • 922 Answers
You do not need to do anything to play online games unless you are the server. If you are the server you need to identify the ports the game uses and forward them through your router to the IP address of your game server computer.
Posted on Oct 12, 2010
Testimonial: "awesome and very fast help"
Riziel
  • 116 Answers
SOURCE: How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
Ok in order to help you resolve this issue I need more information. Is this a newly setup router? Did you setup any type of security? WEP OR WPA these are encryption tools that allow only you to get onto your network.
Posted on Nov 26, 2007
  • 58 Answers
I assume you know the ip adress of your xbox.
First of all check on your router to see if UPNP is enabled.
Then go to Portforwarding/Port triggering.
Then add custom service
service name: the name of how you call it. doesn't matter really
service type is UDP
start port 88
end port 88
server ip is the adress of your xbox
then apply and make another custom service
name it how you want
service type tcp/udp
start port 3074
end port 3074
server ip adress of you xbox
this should work
Posted on Jan 03, 2009
  • 8 Answers
SOURCE: Strict NAT type on xbox live...eircom is provider, there router
Follow this link and it'll tell you exactly what to do if the router your using is an eicom netopia http://xbox360help.blogspot.com/2007/09/xbox-live-eircom-router-netopia.html
I had the same problem when i started 3 years ago. now i recently bought the new wireless adaptor and have one of the new routers from eircom and after 20 minutes during gameplay it disconnects me from xbox live.it is really startin 2 annoy me now. does anyone know what could be causing this to happen??
Posted on Jan 24, 2010
Tom Marvolo
  • 708 Answers
SOURCE: change nat type from strick to open
1)NAT STRICT
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox
Step 7: Get the IP Address of the Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Posted on Aug 12, 2010
How to set XBOX nat type to open?
Xbox one? If so go to settings and look at net work (or where ever your Nat type is displayed) and click the button with the word multiplayer on it (it checks the multiplayer speed) then when it's done and complete don't back out at that "complete" screen hold the following buttons LT, LB,RT,RB at one time and it will give you an accurate report of your Nat then back out and look at your Nat type if it didn't work the first time repeat. Hope this helps
May 12, 2015 | Microsoft Xbox One
One friend and I can not get into each others lobby
I know 1st hand that there has been an issue with the game network, not the game. Also you have to have a nat type two which means you are linked to router straight, as well as an open nat type in the game. The way to insure you have a nat type 2 is by Going into your router and synching the DNS server and setting up the PS3 with a Static IP as well as putting that IP in your routers DMZ. If either of you or your friend is in a nat type restricted you will not be able to get into eachothers lobby.
Feb 10, 2011 | Activision Call of Duty Black Ops
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
you should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
Jan 18, 2011 | Video Game Consoles & Games
How do you open nat type on the ps3 ?
Nat type is actually defined by your isp..(internet service provider) some companies do not actually support gaming and therefore their service is considered "strict" by ps3 standards for multiplayer gaming online. You may have to reconfigure your pc internet security settings on the computer itself...possibly logging into your router/modem. If this is not helpful or u are unsure of how to do this, contact your isp and explain to them you want the nat type changed...basically they will either not be able to at all and then u need a new isp or they can do it in a matter of minutes and ur nat type will change and give u full access to ps3 online within a matter of hours...hope it helps and u get back to gaming!
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Jul 30, 2010 | Computers & Internet
Hi how can i change my NAT type from 2 to 0 ?
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Apr 02, 2010 | Zyxel P660HW-D1 Router
Better online gameplay xbox 360 open nat type
Hey to open your NAT log into your router and look for a setting called DMZ enter your xbox IP (usually starts with 192.168.1.?) into the DMZ box and enable it.
Good Luck & Game on!!! :)
Jan 25, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have xbox live but the nat type is set to strict. How do I change the nat type to open?
All I did was test the xbox live connection then it changed to open again.
Jan 10, 2010 | Microsoft Xbox 360 Console
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
660 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
