Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
WG111 v2 cuts in and out of connection. says scanning for network address. has been working for three months. i have tried everything i know to fix it. thanks chris
  • 922 Answers
Check the wireless access point you are using for problems. If someone bought the same brand near you then they may be using the same channel which would cause the problem you are describing. In that case change the WAP to use a different channel.
Good Luck!
Posted on Oct 12, 2010
For aboutfive years i have successfully had a orange live box installed in my home and, again successfully have 2 wireless computers. How ever my oldest computer doesnt have wireless option installed on to...
First be sure to check the drivers for your Netgear WG111 are up to date and correspond to your Operating System. It is important to note that there are three versions of the WG111. If you visit the Netgear's Knowledge Base site you can see the difference between the 3 versions (v1,v2 and v3) and select the one that corresponds to you. If you don't know what version you have look for a v1, v2 or v3 after the model name:
After you determine which version you have, let suppose its v3, click the link corresponding to it and download the Software Version 2.0.0 (Supports Win 7) if you are using Windows or the WG111v3 Mac OS Driver Version 1.0.0.0 if you are using a Mac. Once you download the file, run the executable file and install the driver/software for your device.
If your problem is not with drivers then youshould look at you Wireless Network Setup. Please Check that the router has a source of a working internetconnection plugged in correctly via an ethernet cable. Also, routers need fromtime to time to be rebooted. Try disconnecting the router from the power sourcefor 15 to 10 seconds and connect it again.
Post more details concerning your OS, the router you are using and what type ofinternet connection you have(DSL or Cable).
Mar 05, 2011 | NetGear WG111 802.11g/b Wireless Adapter
I've connected everything using Wireless-G USB Adapter WG111 - yet I still can't access the web or even find an icon to access the web. What am I doing wrong?
you need to connect the wireless adapter then you need to configure it i.e need to enter username,password in the page u get when u enter the IP address u got with the adapter in internet explorer
May 28, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
WILL THE NetGear : WG111 54 Mbps WORK WITH ANY WIRELESS ROUTER IF SO WHAT DO I DO TO MAKE IT WORK thank you
Well this adapter works on 2.4 Ghz G standard network. You can use any router that operates at 2.4 Ghz.
To make it work, perform the steps below:
1. Double click on WG111 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.1.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
If issue persists, please contact the router manufacturer for the exact information on how to find the WEP KEY.
Also, disable any firewalls which you have installed on the computer.
Hope this helps.
Sep 28, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wg511 v2 'sees' the network but just won't connect just keeps scanning, updated to latest driver but still no go. Pulled out old WG111 v2 USB wireless card and it connects straight away. Pull the Wg111v2...
Follow the step below to configure wireless connection.
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 30, 2009 | NetGear WG511T 802.11g/b Wireless Adapter
Netgear WG111 v2
go to manage wireless networks.. click on the network name choose manually configure.. set your wep key in there
Jan 06, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
No internet on Wireless home network despite ''excellent'' signal
When Windows Wi-Fi utility reports available wi-fi networks, does yours show up? I would imagine so, if you're being prompted for the key, and you entered it. So, you should be connected to the LAN at that point.
Then it is a question of connectivity. Using "My Network Places", see if you can detect the other computers on the Local Area Network. If they don't show up, but all indicators say you are connected, right click on My Computer, then Properties. On the popup box, you will see "computer name", and beneath that, "workgroup". Make sure that computer is in the same workgroup as the rest of the network. If not, the bottom button will allow you to change the name of the workgroup.
If you can see the other computers on your network, but you just can't reach the internet, take a look at whatever firewalls you are running, and make sure that PC isn't being blocked by one of them. An easy way to check is to temporarily turn all of them off, and see if things start working.
Also, if you can access your hub (using the web interface), check there and see if the Dell desktop is showing up as a connected device at the router.
I would almost bet it is a workgroup issue, but if it isn't, let me know. There are several other things we can take a look at.
Cheers
Nick
Nov 16, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 Wireless 54Mbps USB Adaptor cant connect to the network
dont remember what my security key or passphrase is comp went down and wiped it out had reinsal can you help me
Oct 22, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Stupid router
SUE NETGEAR PURPOSE OF WIRELSS ADAPTER IS TO CONNECT WIRELESSLY, IDIOTS
May 26, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 usb 2.0 adapter lossing connection
you need to set your ip addresses on your computer this is done by clicking start - my network places - on left view network connections - right click on wireless for wireless and on normal lan for lan - click properties scroll down to tcp ip sttings - right click - click properties - click use the following ip address - type 192.168.0.2  - click sub mask it will auto fill then default gateway needs to be 192.168.0.1  - then click use the following dns server and type 192.168.0.1 click ok and your done for every computer you add to the network you have to change the last digit of the ip address such as 2 then 3 then 4 this only applies to netgear routers
Oct 18, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
87 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
