Question about Homelite Garden
Homelite U2T608 edger/trimmer will not start. New plug gaped properly. Dropped carb, dissembled and cleaned out all ports. Fuel is flowing and is new. Motor wont even "cough." Suggestions?
    President:
  • Homelite Master
  • 1,545 Answers
Check the magneto for spark. Remove the plug and reinsert the wire and hold it against the engine as you pull the starter. You should get a nice, blue spark. If you don't see one, the magneto to flywheel air gap may need adjusting or the coil module is bad (rare). You basically need good compression, fresh fuel, good clean air intake, and a strong spark to get it to "pop." I realize you may know these things, but, most people are unaware of the .010"-014" air gap required between the magnets on the flywheel and the legs on the coil module. Disassembly is required to get to it and you take the same steps you would if you wanted to fix the pull rope. A standard business card has about the proper clearance needed between the aformementioned parts. Post back if needed. I am here to help.
Posted on Oct 12, 2010
Testimonial: "Appreciate your input. Will re-disassemble and check gap as suggested. Unit unused for several months but worked last week. Weird!"
  • 1 more comment
  • Roy Cagle
    Roy Cagle Oct 13, 2010
    I wasn't aware the unit worked last week but in looking at several of these trimmers, you do occasionally find one with gap closed up. That being said, you may just need to readjust the H and L screws on the carb to get it to "pop." If you can get it to "pop", then you can probably get it to run.
  • lentill244 Oct 14, 2010
    Finished accessing magneto, Used fine sandpaper to restore clean surfaces on flywheel and coil magnets. Reset gap with business card, as recommended. Found filter in gas tank had disconnected. Threaded thru new fuel line and reconnected fuel filter. Am not sure re H
    You're the Man! Did all as mentioned in previous reply re magneto and fuel filter. Primed unit and first yank on starter cord did it. Started up beautifully. Thanks so much for your suggestions
My homelite starts good,when warm wont run when pull throotle on
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ~~
Feb 03, 2012 | Homelite Mighty Lite Lawn Trimmer
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
My homelite trim n edger will not start. I changed the spark plug, changed the fuel filter in the tank. I am getting a spark at the spark plug wire
Hi cookinmechan. I will try to help out. Did you check the air filter to be sure it is clean? It could be the fuel tank vent that is located in the tank cap. Air should be able to go in and nothing should be able to come out, making it difficult for the carb fuel pump to bring the fuel to carb. Check the fuel lines for any cracks or degragation that could be plugging them. The carburator might need cleaning and new carb kit. There is a fine mesh filter in the carb that needs to be cleaned or replaced. That is a common problem with this type of carb. There could also be an air leak so you might want to check the screws and bolts for proper torque to make sure that doesn't happen. Is there a primer on the carb? Make sure it is working and hasn't come hard so that it doesn't pump enough gas to help start engine. Something that most people and some mechanics don't look at is carbon build up in the exhaust port making it difficult for exhaust. Remove the muffler and look for carbon build up. Sometimes there is not much of an opening for proper exhaust. To clean, bring piston to top dead center and get a piece of wood or plastic to scrape out carbon. Do not use any type of metal so no damage is done to piston or cylinder wall. I hope this helps you out a bit. All the best and good luck. Questions welcome.
Feb 10, 2011 | Homelite Garden
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite ST-155 trimmer; fuel air mix out of adjustment (operator error!). Will not start. Cleaned fuel filter, cap filter, added new fuel w/proper mix. Need basic fuel air adjustment to get it started.
do you have adjuster screw's on the carb???
if you do then screw them all the way in then back them out about 1 and half turn then slowly adjust until correct setting's are reached
Aug 18, 2010 | Homelite Garden
Homelite will not start
the carb is probably plugged or gummed up or the diphrams are hard and not flexing to pump fuel.
Apr 30, 2010 | Garden
Have homelite weed trimmer that won't start
recheck carb dighram is located properly! & that its sealed at the mounting of manifold to head!
Jul 24, 2009 | Homelite Garden
Homelite String Trimmer not firing.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 15, 2009 | Homelite Garden
Homelite Trimmer Carb Problems
Did you look at the muffler? With the two stroke oil, it will tend to get clogged up and restrict the exhaust flow. Exhaust flow restriction equals intake restriction. Just scrape the build up off the exit of the muffler. this is common.
Apr 29, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
218 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
