Question about Wahl The Peanut Hair Trimmer
How do I remove the blade on my wahl peanut trimmers
shaggyrat
  • 1224 Answers
SOURCE: Wahl Peanut model 8685
yes they make current adaptors for everything these days but you will need to change the regional code to work properly
Posted on May 10, 2008
askmannyssha
  • 76 Answers
SOURCE: does the Wahl Model AC Trimmer have an adjustment
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Posted on Mar 30, 2010
brector3
  • 1610 Answers
SOURCE: the wahl peanut has the same motor than wahl tid bit?
the tid bit and the peanut are the same clipper. you will find the tid bit clipper at shaveroutlet.com. See link below
http://shaveroutlet.com/wahl-tid-bit-professional-compact-clipper-trimmer.html
Posted on Jun 23, 2010
SOURCE: I have had my current Wahl Peanut trimmer for
if you use this peanut trimmer on a daily basis the blade is worn. On the peanut trimmer you can't sharpen them or adjust them, just replace them with a new one. On the other hand if the peanut blade was biting since you purchase it Wahl will fix at no charge.Most likly they will send you a new blade.
Posted on May 12, 2011
SOURCE: how do i adjust the
How do i adjust my peanut clippers
Posted on Aug 16, 2011
How do I get the wahl peanut apart to clean it?
Pop the blade off, just push teeth away from the body. Two screws where blade came off and one screw towards the rear at the bottom.
May 04, 2015 | Wahl The Peanut Hair Trimmer
How do i replace the blade
Push the teeth away from the housing and the blade will click off. The new one will just click back on. Suck out the opening with a vacuum cleaner, The new blade will come pre-lubricated in the driving slot but the blade will need periodic oiling. You need to remove the blade to properly lubricate the back edge of the blade.
Apr 09, 2015 | Wahl The Peanut Hair Trimmer
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
How to open wahl super trimmer model 1591/1592
Push the blade teeth away from the trimmer body, it will just click off. Undo two screws behind blade, undo one screw at rear of trimmer from the bottom. That's it cases will now split apart.
Jan 19, 2013 | Wahl The Peanut Hair Trimmer
I have had my current Wahl Peanut trimmer for about 8 months. Recently it is "biting me". In other words, it seems all of a sudden the blade is sharp on my skin and has not been so in the past. I...
May 11, 2011 | Wahl The Peanut Hair Trimmer
How do I take the blade off
Hold the peanut trimmer in one hand, place a your thumb on the blade with a wash towel pull the blade back, it should pop off. When replacing the blade, the blade has a plastic notch on the bottom where is round, insert that notch into the square hole on the trimmer and push back. it will snap on.
May 10, 2011 | Wahl The Peanut Hair Trimmer
The wahl peanut has the same motor than wahl tid bit?
Jun 22, 2010 | Wahl 8685 Hair Trimmer
Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Jun 24, 2008 | Wahl The Peanut Hair Trimmer
Wahl The Peanut Hair Trimmer Logo
1,215 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
