Question about Dryers
I have an admiral clothes dryer model # ADE70000AYW that stopped running during use. I have checked the breaker, the power source connection and the connection to the terminal block and everything checked ok. Also, the interior light does not come on. Any ideas as to what could be wrong?
  • 744 Answers
It sounds like the thermal fuse failed. See the link below to the wiring for the unit. The thermal fuse is in the upper right-hand corner of the drawing.
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1319576&pkw_=basket&model_id=5167368&NewWindow=1
The thermal fuse should be mounted on the back of the dryer on the air duct.
Also see this link for additional information:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167368&diagram_id=1319576#d1319576
Posted on Oct 12, 2010
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral Dryer, runs bu t does not heat
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Nov 17, 2014 | Admiral Dryers
Control Panel Doesnt Light. Breaker is good. Interior bottom light works ?
possible bad connection to the cord, inside the dryer.. unplug it, remove the rear panel, and do a continuity check with a meter.
Mar 11, 2014 | Maytag Neptune MCE8000AY Electric Dryer
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
I have an Admiral Dryer - Model # LNC 7766A71 and it suddenly stopped in the middle of drying clothes. There is power running into the dryer - checked with a volt meter and replaced the power cord. Still...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 21, 2011 | Dryers
MAYTAG ADMIRAL DRYER MODEL LNC7764A71 STOPPED RUNNING ABRUPTLY DURING A CYCLE AND WILL NOT START IT HAS POWER AND THE THERMAL FUSE HAS BEEN REPLACED STILL NOTHING
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 01, 2011 | Whirlpool LER5636P Electric Dryer
While I was out of town my wife was drying clothes and she said the dryer stopped, and when she opened it the clothes were still damp. She tried to re-start the dryer and it would not start. She called a...
you must check if there is power to the element when you have it switch on , , if you have no power to the element , then trace the wiring from the element to a hi limit thermostat , it a small round disc shape item about the size of a 10 cent coin with two connections , remove the wires and check continity accross the two terminals, if it is ok , then check the on and off switch or timer dial , you might see burn marks around the connections , since it trip the circuit breaker
Jul 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Dryers Logo
135 people viewed this question
Top Dryers Experts
