How to reset bois for a MSI laptop model # ms-no11
  • 570 Answers
When you first turn your computer on, you are briefly presented with a BIOS "splash" screen. Somewhere on this screen (just where depends on the manufacturer), are instructions on how to access BIOS settings. Generally, this requires tapping a function key, say F2, while the splash screen is visible. Make note of which key the splash screen says to press to access the BIOS and restart your computer.
When the computer boots and the splash screen appears, tap the required function key quickly to enter the BIOS settings screen. You will only have a couple of seconds to hit the right key and if you miss it you'll have to restart the computer and try it again.
Once you successfully enter the BIOS settings screen, use the arrow and function keys to navigate the menus. Keep an eye out for an option that says something akin to "reset to factory defaults." If you see this, follow the on-screen instructions to reset the BIOS to the factory settings. Then, confirm your choice and exit the BIOS screen, usually by pressing escape. Congratulations, you are done.
If your BIOS does not have an option to return to factory settings, things are more difficult. Because the BIOS is stored in ROM, it must have a constant power supply to store any changes you make to it, otherwise it would reset every time you disconnected your laptop from AC power. Removing power to the BIOS resets it to factory settings and involves disconnecting a small battery attached to the motherboard. On many laptops, the BIOS battery is easily accessible through a door on the bottom of the unit. Unplug the computer, remove the main battery and touch something metal to ground yourself.
5
Remove any screws holding the BIOS battery door in place. Then identify the battery, (it is generally a small lithium "watch" battery), and remove it taking care not to damage any surrounding circuitry. Let the computer rest for a minute or two to discharge any remaining power, and replace the battery.
6
If your laptop does not have an easily accessible door for the BIOS battery, you may have to dive deeper and disassemble the computer to find it. Consult your laptop manufacturer's website for information on replacing or removing the BIOS battery from your model.
Thanks.
Have a great day.
Posted on Oct 12, 2010
How to install bios
the bios is already on the board,
when you are booting the computer you have to push down on the F10, if that doesnt work than try F1 and thanF2, every time you try to enter the motherboard bios you have to start from a cold boot.
website for motherboard bios configuration and settings is at
http://www.msicomputer.com
if you want a copy of the bios setup and configurations and everything explained in detail go to your browser and type the following information.
MS-6758-040 BIOS MANUAL OR
MSI MS-6758-040 BIOS MANAUL
the bois controls everything the that runs you computer, video, ram, HD, CPU, PORT FUNCTIONS, BOOT SEQUENCE, SMART FAN CONFIGURATION, HD CONFIGURATION, TEMP. SETTINGS, AND ALOT MORE STUFF AND VERY LONG LIST.
MAKE SURE THE BATTERY IS MIN. 3VOLTS
Jun 25, 2014 | MSI MS-6758-040 Motherboard
How to install built-in cam?
Try the MSI website, Support section. and download the drivers from there.
May 02, 2013 | MSI 320GB Hard Drive for Wind U100, Wind...
Msi msn014 factory reset method
how can i reset my cmos password for msi ms-n014
Apr 04, 2013 | MSI MS-N014-ID1 Netbook PC -...
How to replace hd in msi model ms-1313
not sure about this model, but most lappys you unscrew the bottomof the laptop off and the hard drive is in side. most have a swing out cartridge that the hard drive slides into. on my msi it has a small brace with 2 screws. I take that out.. add my new hd and slide it back in. easy peasey.
Jan 09, 2013 | MSI Computers & Internet
Looking for a display inverter cable for msi megabook s270
Here's an MSI lcd cable but make sure it matches the model number on your lcd cable. It did not say it was for megabook S270 but some other models. Most cables go across different models.
http://www.ebay.com/itm/Original-New-MSI-Megabook-MS-10351-MS-163C-LCD-Video-Cable-K19-3036002-H58-/250966405323?pt=US_CPU_Fans_Heatsinks&hash=item3a6ec370cb
Jun 02, 2012 | Computers & Internet
MSI Wind MS-No11 built-in webcam with installed driver doesn't work.
yep, you doesn't say which operating system do you use? if you use windows 98 then this windows cann't detect any new hardware without install it driver software. but if you use windows xp professional then it can detected. but for many reason sometime it cannot work. as a result, you need to repair your windows or format your windows then it become ok thnaks
Oct 26, 2010 | Computers & Internet
Reset bios on MSI ms-7301 motherboard
Kindly visit the following site
http://www.msi.com/index.php?func=downloadindex
Select the correct model number for your mainboard or motherboard and download the user manual for the same. It has details on how to reset the cmos or the board using the jumper settings
Thanks for using fixya
proton
Aug 15, 2009 | MSI Computers & Internet
MSI MS-1036 with missing parts
this was i found, where you can get the parts you need for your laptop..
CLICK HERE...
and if you want to see the MSI website there at GERMANY..
MSI GERMANY
Kindly rate my solutions, will yah..?
Jun 21, 2008 | MSI MS-1036 Barebone
Bois setting
try to return it original setting of the clock.you over clocked it so it seems the monitor cant handle it.but somehow i dont think changing the clock would affect the monitor coz its two separte hardware.
but the important thing to do is return the normal clock setting okey.
god bless
May 30, 2008 | ASUS P4B266 Motherboard
Computers & Internet Logo
782 people viewed this question
David Payne
David Payne
