Question about CRL Corded Electric Drill - 3/8" Keyless Chuck - 110 Volts
One of the three grips that hold the bit in, fell out. How do I put it back in.
I can't get the chuck to work or open to change the drill bit. I have really tried!
Hi Alice:
Is this a "key"? If so, put it in place with the drill pointing up and the key handle pointing level and towards you. A light tap with a hammer on the key handle should loosen it.
If it is a "manual grip", try putting the drill in reverse, and at low speed. Hold the drill handle with your right hand, and hold the grip firmly (really firmly) with your left hand, and squeeze the trigger. It should release the chuck. If it doesn't, try putting a pipe wrench on the grip.... gun facing away from you, wrench from the top, handle on right. gently tap on the wrench handle should loosen it.
Cheers.
Apr 08, 2016 | Ryobi Drills
How to stop my grips slipping?
Put the grips in hot soap'water let them soak .take them out let cool off clean and rinse them off with luke warm water after cleaning them also inside the grip hole, clean the handle bar with alcohol. Put them back on and twist them till they become a bit stiff than let it dry. It will grip the handlebar.
May 29, 2011 | Freestyle Mongoose Bmx & Owners Manual -...
Changing grips. Any suggestions or warnings, expecially on the throttle side? 2006 HD Dyna Street Bob
Usually when you change the grips on the throttle side, depending on what type of replacement grips you bought, you'll be replacing the throttle sleeve as well. This means that you will be messing with the throttle and idle cables.
Loosen both cables at the adjusters as loose as they will go. Then, remove the two bolts that hold the right hand switch housing together. Carefully seperate the two halves. Do not damage the wires going to the switch. Work the throttle cable and the idle cable out of there slots in the throttle sleeve of the old grip. Be careful not to loose the brass ferrel that goes over the cable end. Lubricate the inside of the new throttle sleeve, the handlebar, and the area where the cables hook up with white lithium grease. Reassemble cables into new sleeve and reassemble the switch housing.
Once you have everything back together, adjust the throttle cable first and leave just a bit of slack in the cable. You should be able to freely "rock the throttle grip" before you feel the cable tighten up, Just a bit. Then adjust the idle cable about the same way.
Now, Turn the throttle cable to Wide Open throttle position and release it. It should "snap" shut, do this again from half and quarter throttle to make sure it works as it should. Failure to insure that the throttle operates properly can cause serious injury or death.
If you are simply replacing a grip on each side of the handlebar, use a long slender blade screwdriver or an ice pick to slide between the handlebar and the grip. Spray some WD40 in the work the grip a bit and it will break loose. Clean the throttle sleeve and handlebar off alcohol. Now, some people like to use "Grip Glue" on the new grips. Put the glue inside the grip and slide it up on the handlebar. If you put the glue on the handlebar, it will roll up in front of the grip as you slide it on to the handlebar or throttle sleeve. Make sure you "align" the two grips so they look the same before the glue sets.
Good Luck
Steve
Jul 18, 2010 | 2006 Harley Davidson FXDBI Street Bob
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
Cannot remove drill bit from self locking chock
If you are having trouble turning the chuck to remove the drill bit just wrap a cloth around it a couple of times and use a pair of adjustable channel lock pliers to give yourself a mechanical advantage. If you have loosened the chuck but can't remove the bit just clamp onto the bit with a pair of vise grips and tap them a few times with a hammer while a friend holds the drill for you.
Nov 09, 2009 | Drills
Handle grip problem, 2005 Suzuki Boulevard C50
the only way is to get some locktight or super glue on it to keep it in place for a bit.
Sep 08, 2009 | 2005 Suzuki Boulevard C50
My Motorcycle fell over!
Chances are the forks are just a bit out of alignment from the fall. Put the bike on the center stand with the front wheel pointing perfectly straight ahead. Are the handlebars looking like they are turning a bit to the left or right? If so, just go to the front of the bike and straddle the front wheel while facing the rear of the bike. Hold the wheel firmly with your legs and firmly twist the bars back to a straight position. Re-check the alignment and re-adjust as needed. Now go ride and check it out.
Please rate this solution. Thanks!
Jun 09, 2009 | 2003 Suzuki VL 800 Volusia
Piece fell from middle electrical post and screw won't tighten
Ity was most likely the nut that holds that bolt tight. See if you can find it, hold it to the back of the wall the bolt screws through and see if that does it. Note Turn the breaker off at the service panel first.
Sirwriter
May 01, 2009 | Whirlpool LER5636P Electric Dryer
The drill bit came out of my xrp 12v dewalt drill. How do I get it back in? Is it locked?
I hope I am understanding your question properly, if not, leave a comment. This drill *** a "keyless" chuck. If you look down into where the drill bit goes, there are metal pieces inside the black nose of the tool. Those metal parts are what holds the bit into place. The drill bit slides into the hole at the front of the drill (where it fell out from), Put the drill bit back in and then grasp the black tip (right below where you put the drill bit in). Directly underneath where you put your first hand, hold onto the piece directly below the upper part. Turn the top piece right and left and it tightens or loosens the mechanism that holds the bit in place. Give it a firm turn to make sure it is tight.
Jan 10, 2009 | Dewalt 18 Volt Compact Drill Kit
CRL Corded Electric Drill - 3/8" Keyless Chuck - 110 Volts Logo
13 people viewed this question
Top CRL Drills Experts
Are you a CRL Drill Expert? Answer questions, earn points and help others
