Question about Tomtom GO 910
How do you get inside the tomtom 910 to change the battery please.Is there a maual? Cliff
    President:
  • 2,777 Answers
There is no real manual for this, I have done it before though and have typed out the directions here for you, plus a link for the new battery if you need it:
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
New Battery:
http://www.amazon.com/gp/product/B000WVUFUW?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B000WVUFUW
1) Remove 4 screws under ends of rubber strips on back. (All screws are Torx number 6)
2) Remove back cover. Front frame around screen comes off easier now.
3) Remove 2 screws in round top circuit board. Remove 4 screws from lower circuit board. These two boards may have a glue connection. Do not worry if it separates
4) Lay back circuit boards to unplug battery. Note flat ribbon cables are fragile. The 3 wire plug is the battery. Unplug wires to battery from receptacle on circuit board.
5) Remove front screen by pressing a screwdriver against the small metal tags that follow the edge of the screen. The tabs need to be pushed in slightly to allow you to lift the screen out. It may need some leverage, but be careful not to put the screwdriver to far behind the screen as there are a couple of thin cables for the connections.
6) To remove the hard drive you may need to unscrew the vertical black tags about 2 cm long. These simply come away and are grasping the business card size silver box IE the hard drive. The rubber end caps are pressed in, pry out with small screw driver.
7) Remove battery and replace. Note the two sided sticky tape around battery. When putting more tape on, be careful you do not put to much around the right hand end as it will connect with the thin cable when you put it all back together.
9) Reverse assembly. Mine works fine now, good luck. (and so does mine! BLP)
Footnotes: I did not have a Torx #6 screwdriver nor could I buy one locally. I found a #7 mini star bit works just fine. Source: Harbor Freight item # 93316, 6 piece Mini Star Bit Set - $3 PMVN - 9/19/2009
I am not advertising but Batteryship.com included with the battery #5 & #6 torx screwdrivers, a very small philips (star), a straight screwdriver and a plastic pry tool. Whatever I paid more than another place it was worth it.
When disassembling do not remove the battery clip. Just pop out the battery from the front (experienced having to reassemble that whole thing). Also having a set of tweezers to put the electrical connections back together helped a bunch.
Thanks
Tim
Posted on Oct 12, 2010
When removing the 910 from power lead it dies, which leads me to think batteries are dead, can the be pelaced by owner or be returned to TomTom?
well the battery is intended to be replaced by TomTom professionals, but you can change it yourself if you have the proper expertise, You can buy the spare battery from Ebay etc.
Jul 16, 2010 | Tomtom GO 910 GPS Receiver
Tom tom go 910 red cross flashing wont re set
Well i am writing this wile I am trying this out...
I have a TomTom Go 910 that has a RED CROSS FLASHING on the bottom corner, what I have found is that if you have backed up your TomTom Go i maybe able to reset the TomTom Go on my computer but if you havent you may have to find on try finding one on google but i have a TomTom Go 910 you can download the 910 on http://rapiddigger.com/download/backup-go-910-rar-9110176/.
after you found the back-up you can connect your TomTom Go to your computer using the USB provided from your TomTom Go, replace the doggie file with the new one, then this should change it back to the FIRST update given...
(WARNING >> PLEASE scan the file befor you put it in your TomTom Go it might contain a very very evil virus<< WARNING)
Jul 12, 2010 | Tomtom GO 910 GPS Receiver
TomTom 910 - when I turn the deice on the logo
Letting the battery run down will not fix it, so recharge it. I suspect your maps have become corrupted or at worst deleted. Reinstall your maps from the CD or by contacting TOMTOM and quoting your licence number for a download.
Leaving GPS in car subject to extreme heat will danage the card and often the maps. Gloveboxes are not exempt either as they often reach over 50C when car is left in the sun. ( assuming it is summer wherever you are)
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Tomtom GO 910 GPS Receiver
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
Tomtom wont come on
More than likely the negative post on your 910 is not making a contact. This is a known problem for the X10 series tt's. It can be fixed but you have to disassemble the tt to do it. No just replacing the battery won't fix your problem. If it was just a battery problem your tt would still boot up if connected to external power.
Jun 12, 2009 | Tomtom GO 910 GPS Receiver
Faulty battery on my Tom Tom Go 910
Go to this site and get the pdf with pictures on how to do it. Just be careful with the hard drive cable. Delicate tabs.
http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
Jan 31, 2009 | Tomtom GO 910 GPS Receiver
TomTom go 510
COMMON PROBLEM SO FAR WITH THESE. IF STILL UNDER WARRENTY CALL TOM TOM THEY WILL REPLACE THE BATTERY UNDER WARRENTY
Feb 20, 2008 | Tomtom GO 910
Faulty tomtom go 910
have to send it in to get battery replaced.
Jan 20, 2008 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 Logo
376 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
