Question about Sony KDS-R60XBR1 60" Projection HDTV
No audio, controls don't work except on and off button. Picture very dark and black and white. green light flashes for two minutes before picture comes on.
  • 95 Answers
Lamp is weak. replace lamp. this can solve your problem
Posted on Oct 26, 2010
  • audiofilius Oct 27, 2010
    How does a lamp going to solve the sound and controls problems??
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
I have a Sony Wega LCD Projection 60wf655. When I turn it on, the red light turned green and blinks green 6 or 8 or 10 times or indefinitely. No picture but after a minute of being on the screen glows...
This could be the "thermal fuse" which usualy is next to the light bulb. Part cost around $5.00. Please check your manual for directions depending on light and times blinking.
Apr 11, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Need factory wiring codes for a 1999 jeep grand cherokee
battery red/white
accessory white/red
ground black
LF - light green/green
LF + light green/red
RF- light blue/ black
RF+ light blue/red
RR- tan/dark green
RR+ white/violet
LR- white/dark green
LR+ dark green/white
Dimmer orange
This wiring is for the standard audio system
Sep 17, 2010 | Car Audio & Video
My Sony Bravia has no colour, and the black and white is so dark you can't see the picture. It is less than 1 year old model # KDL-46S5100
If the picture has no color or appear as black and white only, please reset the picture setting. To reset picture setting please follow the items below:
  1. Press MENU button on your remote.
  2. Press arrowtb.png to select setting.jpgSettings, then press ok.png.
  3. Press arrowtb.png to select picturemenu.jpgPicture Menu, then press ok.png.
  4. Press arrowtb.png to select Reset, then press ok.png to reset all the Picture Settings except Picture Mode and Display Mode to the factory settings.
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Jun 27, 2010 | Televison & Video
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
Sony KDS-R60XBR1 60" Projection HDTV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
