Question about Rival S16 Electric Skillet
I need Part no e29583-9907 WB tm #1 control - Rival S16 Electric Skillet
    President:
  • 2,777 Answers
This was extremely hard to find but I have it here for you, it is on ebay, but I can vouch that it is working fine and in great shape:
http://cgi.ebay.com/WestBend-Sensa-Temp-Heat-Control-WB-1-1500-W-Cord-/360309017863
Posted on Oct 12, 2010
  • Tim Grayson
    Tim Grayson Oct 12, 2010
    Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do this for me. Let me know if you have other questions about this or want another location to buy it from, I can try to locate it elsewhere, but this one is your best bet.
    Thanks
    Tim
Can i use technomate tm-5000 super series control for technomate tm-3000 series
Hello Hakan.
The tm-5000 does`nt work with tm-3000. It`s only compatible with: TM-5200 D, TM-5300 D+, TM-5400 CI, TM-5600 CI. Not for non super-series. Here is the link to technomate. http://www.technomate.com/store/products/TM%252d5000-Series-Remote-Control.html
Reg.Gue.
Feb 17, 2016 | Computers & Internet
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
C / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
I'm looking for one skillet power control for Rena Ware fry electric pan Cat. 17530
Rena Ware Electric Skillets use the same control as West Bend WB-1 . The back of the Rena Ware Control does say WB-1. Mine is 1500 watt.
You can find the WB-1 eBay for various prices. A generic heat control will probably work as well if it is the same wattage. I have a Saladmaster control that also works for this skillet.1_26_2012_12_42_14_am.jpg
Sep 07, 2011 | Precise Heat KTES2 Electric Skillet
How do iget a code for technomate from my magician remote conntrol
Try these, I can't gaurentee these will work...but hopefully you have some luck with it.
Universal remote code for all Technomate models
Quote: All TM-1000 Series 249
All TM5000 Non super Series 251
All TM-5000 Super series 253
All TM-6000 Series 606
Some universal remotes need 4 digits
Add 0 before above numbers
Example 0249
http://starview-6.info/?p=308
Mar 03, 2011 | Universal Remote Control
Need a heat control cord for a west bend electric skillet model 73010 on bottom it says to use only a #1 or #6 control
Usually, appliance parts supply companies will have them. We have a really little shop near us, and they stock them.
Best regards, --W/D--
Feb 07, 2011 | Microwave Ovens
I need the heat control plug for rena ware frying pan can you help please?
You can find the WB-1 ebay for various prices. A generic heat control will probably work as well if it is the same wattage. I have a Saladmaster control that also works for this skillet.
Dec 05, 2010 | Precise Heat KTES2 Electric Skillet
Filled truck up with fuel and fuel guage stoped working
There is a TSB for this issue ( TSB 08-2-9 ).
The problem is high sulfur content fuel will cause a problem with the fuel level sending unit, and cause it to read incorrectly.
The 2 times I had this happen, I was not at my normal brand fuel ( had it happen with Shell fuel both times ).
I fueled at 1/2 tank with my normal brand, and then after another 1/2 tank fueled again, and the problem went away.
If you want, the TSB lists new revision fuel level senders, that you can drop the fuel tank, and replace your exiting one with to cure the problem.
The correct P/N depends on your truck cab & bed config, and options
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132 WB
8L3Z-9A213-F Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139 WB
8L3Z-9A213-G Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-H Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163 WB
8L3Z-9A213-A Kit - Fuel Sender 2004 through 2008 - Gas-26 Gal Tank - 126/132 WB
8L3Z-9A213-B Kit - Fuel Sender 2004 through 2008 - Gas-30 Gal Tank - 139 WB
8L3Z-9A213-C Kit - Fuel Sender 2004 through 2008 - Gas-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-D Kit - Fuel Sender 2004 through 2008 - Gas-36 Gal Tank - 145/151/163WB
Aug 20, 2010 | 2004 Ford F150
One touch white balance
i have the e-500 and can only register one at a time. once you set the white balance using the one touch button, it stays that way until you one touch again or custom reset. however it may be possible to save to 'my mode' 1 or 2 ... or even 'custom reset' 1 or 2. according to the manual on page 119, it saves your wb setting and most of the other changes you have made.
reset camera... soft reset. Mode Dial to P, press Menu, right arrow (AF button), to card setup, down to custom reset, right to custom reset, OK, up to YES, the OK
Sep 24, 2008 | Cameras
SONY DSC-W1 - Images have a greenish / blueish tint to them
More likely than not its a WB issue. Were you using manual or automatic WB? sonys are known for not having the best auto WB mode :) Try using manual WB and see if that helps.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Flash pictures too blue - optio 750z - help?
Try playing with the exposure compensation lever. Turn it down a few notches when you use flash. I do that all the time to prevent over exposure Or you can set the flash compensation in the setup.
Aug 30, 2005 | Pentax Optio 750Z Digital Camera
Rival S16 Electric Skillet Logo
359 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
