Question about Whirlpool Kitchen Ranges
Whirlpool Wall Oven sometimes power fails in middle of a baking session. Display goes blank and oven will not work for 10-20 minutes. Then oven will come back on with a PF readout.
  • 413 Answers
Could be several things; 1. Electrical connections in oven are loose. 2.The circuit breaker for the oven could be failing. 3. The electronic control is failing. Make sure when oven is operating, the cooling fan is operating. If the cooling fan is not working, the electronic control will overheat and shut down.
Posted on Jun 01, 2008
Replaced the LCD pad computer. getting a LOC rEF code. What does it mean or how do I clear it?
If this is a GE oven:
1. Make sure power to the wall oven is turned off_
2. Completely close the wall oven control panel and return the wall oven to its normal installation_
3. Apply power to the wall oven. Accessing the control panel area but not replacing the control:
4. Enter Special Functions mode by pressing the BAKE and BROIL keys at the same time.
5. Reset the control by pressing the 9 and 0 or the HOUR DOWN and MINUTE DOWN keys for 3 seconds at the same time.
6. Approximately 20 seconds after the time of day is displayed. press the 1 and 5 or the TEMP LIP and MINUTE UP keys. The control should briefly go blank, briefly display all segments. briefly 'display "LOC FIEF," display all segments for 30 seconds, and then display "LOC REF:"
7. Acknowledge the "LOC REF" command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. The control should then display the time of day,
8. The oven should be ready for normal operation.
9. Test the functionality of the glass touch contra especially the CLEAR/OFF and/or CANCEL key(s)..
Nov 26, 2015 | Kitchen Ranges
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
I have whirlpool built in electric oven model RBS305PRS00.When baking sometimes the oven will cut off and display EO F3 is this an error code?If it is an error code what does it mean and what do i ne
This is typically the oven sensor that is bad. The sensor is the pencil size probe in the oven. They usually can be pulled out from the front. and have a disconnect clip. very easy to replace.
Nov 18, 2014 | Whirlpool Ovens
I have a Whirlpool Super Capacity 465 and am having issues with the following. Sometimes while baking, the oven turns off and the power to the appliance stays on, sometimes everything shuts off and PF
PF stands for power failure you are loosing incoming power power check the terminal block the control will do goofey thing with loss of voltage rule of thumb no more than a 10% voltage loss 108VAC minuim
Aug 04, 2014 | Whirlpool Ovens
Replaced control panel on whirlpool electric double wall oven. e1 f5 code pops up,fault code says check door latch. checked switches on latch with meter check ok.what to check next
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$RED
Feb 28, 2010 | Whirlpool RBD275PD Electric Double Oven
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Whirlpool Wall Oven not working
It is likely the Thermal Cut-Off (TCO) fuse, which for many Whirlpool ovens is located on the back of the unit. Turn the circuit breaker for the oven OFF first. You'll need to remove the trim on the left and right side of the oven (2 screws) and then remove the screws holding the oven in the wall. You can locate it easy enough by looking for the thermal fuse on any of the major appliance part websites. The test is simple enough if you have an Ohm meter, as it will be an open circuit if it is blown. There is only one fuse (normally) so if it is blown neither the bake or broil element will work. There should be a Tech Sheet located behind the control panel which will help, but if you don't feel comfortable doing this call a service tech.
Apr 02, 2008 | Whirlpool RBS245PD Electric Single Oven
Whirlpool electric oven
hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
Nov 30, 2007 | Ovens
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Kitchen Ranges Logo
241 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
