Question about Cell Phones
I have a new-ish LG phone with a new battery through Verizon and it has a really bad charger connection, and it either won't charge or charges only halfway . I have already been through a nightmare with so many crappy new phones just in this past year. Do I have to buy yet another p.o.c. phone that prob will break after 3 uses, or not work right from the get-go? I have NOT dropped it, spilled anything on it, left it in the sun, etc. I don't have the money to buy a new or a fancier phone. In the past, have people been able to get this problem repaired on the phone? I think its the connection inside the phone, not the charger. Thanks, Jody
My Lg is not keeping charge, and I bought a new Battery and it still wont charge or keep charge. Please Advise.
A charging problem could be due to a bad battery, corrosion on the battery contacts (you can clean them with rubbing alcohol) a bad charger or the charger plug on the phone. I would try replacing the charger and checking the connects.
Jan 13, 2016 | LG Cell Phones
My phone wont turn on or charge even tho i charged it all night
It sounds like you need to replace your battery. But first, if you're using a home charger, try charging the phone with a car charger (or vice versa). If the problem is not with your charger, then replace your battery.
When you get your new battery:
1) Make sure you are using the proper charger for your phone (not one of the cheep $5 kind), and
2) charge your battery for at least 12 hours before you use it for the first time.
Click here to see a battery for your phone on eBay: http://cgi.ebay.com/NEW-OEM-LG-VERIZON-VX8560-CHOCOLATE-3-LGIP-330H-BATTERY-/250764708864?pt=PDA_Accessories&hash=item3a62bdcc00
Jan 28, 2011 | LG Chocolate 3 Cell Phone
Battery Won't Stay Charged
well if you have recieved new batteries and they wont stay charged then the problem isn't the batteries apparently. It could possibly be that your charger has gone bad and isn't charging your battery all the way. I suggest buying a new charger and it should fix your problem and if it's not your charger then it must be the outlet supplying voltage to the charger going bad. More than likely you need a new charger cause it seems like its not getting the voltage it needs to charge your phone.
Jun 09, 2009 | LG enV VX9900 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Wont charge
your charging port is loosely connected to *********** board. You need to go to a repair shop and get it fixed.
Apr 18, 2009 | Verizon Communications LG enV Cell Phone -...
Vx9800 powers off when charger is taken out
sounds like you either have bad contacts from the battery to phone or you have a bad charger connection port on the phone or simply a defective battery try buying a new battery on line i have seen them as low as 20 dollars
Jan 24, 2009 | LG VX9800 Cellular Phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
Won't turn on
You need a new battery.
Nov 19, 2007 | LG VX9400 Cellular Phone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
