Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Do you have some sort of a little light for inside the house to tell me when I forgot to close the garage door?
    President:
  • 3,197 Answers
Sears sells a Wireless Garage Door Monitor for $34.99. The model number is 53696.
Posted on Oct 12, 2010
Testimonial: "I will look for this product. Thank you."
Garage door will open from remote or car;but wont close,only closes by inside wall unit
Something could be blocking the electric eye.they are down at ground level on both sides of the door
Dec 20, 2011 | liftmaster Chamberlain Garage Door Opener...
Can open my garage door with the remote just fine, but it will not close the door. When I try to close it from the button inside the garage I have to hold it down until the door is all the way closed,...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering ever so slightly. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Jun 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
I can open my garage door with the remote just fine, but it will not close the door. When I try to close it from the button inside the garage I have to hold it down until the door is all the way closed,...
Make sure your door sensors are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them.
Sep 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Close garage when leaving house but come home and the garage door is up
if you or your neighbors have a cable booster this is a garage door openers worst enemy try to reprogram remotes or change dip switchs if this is an old operator. make sure you watch door close all the way before you leave and it is not getting hung and coming up add a little pressure if thats all it is...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sensor lights not working on door opener
If the sensor light or receiver gets kicked, it can be knocked out of alignment. If it's not aligned, it will act as though it is blocked -- in other words it will open, but not close.
I fixed my buddy's opener not long ago -- you should have two parts of the sensor, near the floor at the bottom of the door. One is an infrared light, the other is a receiver. The receiver should have a little LED on it. This glows green when it is receiving a clear signal from the other side. If your's is glowing red when you can see that the path is clear, try adjusting the aim of the infrared light. You should be able to gently move the light from side to side until you see the LED on the receiver glow green.
Dec 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door keypad
The blinking on your keypad simply means that a code of some sort was sent. Whether it be the right on or not. Lets try to reprogram the unit. Press the colored learn button on the motor head and then within 30 seconds enter in the 4 digit code followed by the up/down action button. The light bulb should flash to let you know it has been accepted. Wait 5 minutes and try. If it does not work replace the keypad.
Jul 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
How to align the sensor on garage doors
Ok quick question. How old is your opener? There are two little blocks on each side of the door. are they both green? or is one amber and the other green? When I go out to a customers house with this problem the first thing I do is close the door so is a little darker so you can see the lights. Line them up then I good each one a good little tap with my finger and see if ether light will flicker. If so then there too loose or not lined up as well. One side will always be lite (unless there is no power or a cut wire)
Dec 06, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
55 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
