Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I hace cleaned the oven how do I clean the glass in the door?
  • riopatton Oct 12, 2010
    How about the cleaner I use for the burner top would that be ok?
    I asked if I could use glasstop burner cleaner. No reponse
    Genius:
  • 1,478 Answers
Cleaning an oven door glass is not very difficult. You could either clean it after detaching it from the oven or by cleaning it in its normal position. You could either buy the commercial oven cleaning spray or you can prepare your own cleaning solution. Take baking soda in a bowl and make a paste of it by adding some white vinegar. Using a dry cloth, dust the oven off any loose dirt and debris. Next, using a clean sponge apply the cleaning solution of your choice or the spray onto the oven glass door. Oven cleaning spray is not abrasive and seems to satisfy many people. Never spray the cleaner directly on the glass, as it can damage the glass door. Always spray it onto the cloth first and then rub it on. Allow the baking soda paste to sit on the glass for ten minutes. Then wipe it off with a soft cloth. n tepid water add some dish washing liquid and dab this solution onto the glass with a sponge. For tougher stains use steel wool to scrub. Next, use a clean cloth to wipe off the solution. Use another cloth dipped in clean water to rinse off all the soap. Clean all the corners dry. The glass door will be shiny clean. If you have detached the door, then replace it.
Take care.
Posted on Oct 12, 2010
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How to remove glass on oven door for cleaning,zanussi instruction manuals
Oven door glass is not designed to be removable for cleaning.
Jul 19, 2014 | Zanussi Ovens
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
GE 1978 Slef Cleaning oven JKP26002wh 3 Layers of glass in door...How do I clean between the glass in the self cleaning aluminum window mechanism?
You will have to take the door apart to get to the glass that needs to be cleaned out. I would not recommend doing a self clean on an oven that is that old.
Dec 07, 2010 | GE JTP75CMCC Oven
How to clean between doors of a wall oven a
2smart4u did not answer the question - how to clean between the glass on the oven door. I too have streaks inside the glass - looks bad - no way to clean it?
Dec 04, 2009 | Ovens
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Feb 04, 2009 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
132 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
