Question about Pinnacle Studio Ultimate 12 for PC
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
  • 217 Answers
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Posted on Nov 18, 2010
How do I recover from an "Export failure render error 0/45543@00:00:00:00"?
you need to create an image of the file that you want to put on dvd
Jun 08, 2015 | Computers & Internet
Ho to fix problem name blue screen
can you post the actual blue screen code?
Nov 17, 2011 | HP Pavilion dv9000t Notebook
A trough is formed by nailing together, edge to edge, two boards 11 ft. in length, so that the right section is aright triangle. If 15 gal. of water are poured into the trough and if the trough is held...
Find the vol of the water in cu/in
15 * 231 = 3465 cu/in
Change 11 ft: 11*12 = 132 inches
Find the triangular area of the end of the trough; 3465/132 = 26.25 sq/inches
Let x = width of the trough; A right triangle area = [img width="16" height="39" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image001.jpg" alt="1%2F2" v:shapes="Picture_x0020_1"> x^2 = 2(26.25)
x =[img width="53" height="22" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image002.jpg" alt="sqrt%2852.5%29" v:shapes="Picture_x0020_2"> x = 7.2457 inches the width of each board
Find the width of the trough which is the the hypotenuse
h =[img width="69" height="40" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image003.jpg" alt="sqrt%28x%5E2+%2B+x%5E2%29" v:shapes="Picture_x0020_5"> h =[img width="110" height="22" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image004.jpg" alt="sqrt%2852.5+%2B+52.5%29" v:shapes="Picture_x0020_6"> h =[img width="43" height="22" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image005.jpg" alt="sqrt%28105%29" v:shapes="Picture_x0020_7"> h = 10.247 inches wide, also the base of the triangle
Find the altitude of the triangle, which is the depth of the water; we know it's area[img width="16" height="39" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image001.jpg" alt="1%2F2" v:shapes="Picture_x0020_8"> 10.247d = 2(26.25)
10.247d = 52.5
d =[img width="56" height="39" src="file:///C:\Users\user\AppData\Local\Temp\msohtmlclip1\01\clip_image006.jpg" alt="52.5%2F10.247" v:shapes="Picture_x0020_9"> d = 5.12 inches is the depth of the water
Jul 24, 2011 | Computers & Internet
I have pinnacle studio 12 plus when i am publishing the movie it gives a export failure rendor error so i took out all the transitions and then only published half. I checked off the background thing...
Hi
In pinnacle studio as the movie is being rendered, the cursor moves along with it, this way you can find out at what point in the rendering process, the program stopped.
when you get the Pinnacle 14 Export Error; Real Time at some frame, then you know that, that frame may be damaged, so cut a few frames before and after where the cursor stopped, and try again.
if the rendering process stops a few times during the compilation, keep cutting those pieces and try again.
i hope that helps
Thanks
Jason
Az Audio Visual Services
Video Conversion Service - Free Shipping North America Wide
http://www.azaudiovisualservices.com
Aug 17, 2010 | Pinnacle Studio Plus 12 for PC
Error 1606
Re: Please Help Unable to Install TIVO Desktop -- Error 1606. Could not access network location %APPDATA%\
The response to "Echo %appadata%" should be
C:\Users\UserName\AppData\Roaming
A space in the user name shouldn't be a problem, but creating a new user may fix the problem because it will create the account with default registry settings which will hopefully have the missing %appdata% information.
If you want to check on this before creating the new user, just for curiosity's sake, check the following Registry key:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders and check the value for AppData in the right hand pane. If it's missing, then that would explain the problem. It should be as listed above, substituting the UserName with the folder name for the user under Users.
Also check the key
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
The value of this key should be
%USERPROFILE%\AppData\Roaming
More keys to check:
HKCU\Volatile Environement (1)
HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Volatile Environement (1)
The values in (1) should have the full path spelled out, the values in (2) should use the %USERPROFILE% variable in the path. If the value under HKU\.DEFAULT is missing or bad, then creating a new user probably won't work either. If that value is missing, then I would recommend a clean reinstall of Windows because there is no telling what else is messed up also.
The value for AppData in the registry key HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
is C:\Users\Murray Admin\AppData\Roaming
In the key the key
The value for AppData is %APPDATA%
The value for Local AppData is %USERPROFILE%\AppData\Local
In HKCU\Volatile Environement (1)
The value for HOMEPATH is \Users\Murray Admin
In HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value for AppData is %USERPROFILE%\AppData\Roaming (all the keys have the %USERPROFILE%\ )
In HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value in one of the \Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\UserShell Folders keys for AppData is
%APPDATA% (Missing the %USERPROFILE%\ ) --- Could this be the problem???
All the other values within do contain %USERPROFILE%\
Do you think editing the key, adding %USERPROFILE%\ would do the trick? If so, it would be alot eaiser then
a re-install. There is not much junk on it as this pc is only about a month and a half old. The other machine
is about six months old. Both are from the same manufacturer (Compaq) but different models.
Also - Using the set command the value returned for %APPDATA% are:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Murray Admin>set
TEMP=C:\Users\MURRAY~1\AppData\Local\Temp
TMP=C:\Users\MURRAY~1\AppData\Local\Temp
Jan 20, 2010 | HP Computers & Internet
Upgrade for settlers downloads but won't run
I had this issue as well. Download the patch directly from the website, and run it locally. Afterwards the updater won't find a newer patch, and goes directly to the game. I don't know whether this will break again once a new patch is released, but you should be able to manually install it again at that time. Patches can be found at http://www.ubi.com/US/default.aspx under support --> patches.
This link may take you directly to the right place.
http://www.ubi.com/US/Games/Info.aspx?pId=5923&tab=download&dcId=63
Aug 02, 2009 | Ubi Soft Entertainment The Settlers: Rise...
Pinnacle Studio Ultimate 12 for PC Logo
2,188 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
