We currently own an Engel Shopmaster Model 818-4 (capacity 4' x 8' x 18 ga). We need replacement bulbs for the two magnets. Would you know where we could purchase these light bulbs?
3 Suggested Answers
jsinex2421
  • 62 Answers
SOURCE: I NEED to know which
You need to get a transformer to convert it to 110 volts.
Posted on Jan 13, 2009
  • 147 Answers
SOURCE: Replace projection bulb in our LG TV Model RU44SZ51D.
There is an access door on the back with four screws, then the lamp inside has 2 screws and then will slide out. Most places will sell you just the raw bulb, not the whole lamp assembly, so this is a little harder to change. If you can find the whole lamp assembly you can easily change this yourself.
Posted on May 26, 2009
I replaced the thermocoupler and it still will not stay lit.
is the tip of thermocouple in the flame of the pilot.
where the thermocouple screws into the control valve you just tighten it hand tight and then 1/16 of a turn. or you might have damaged the magnet.
is the flame big enough on the pilot light as it might need the jet cleaned.
failing all that then the magnet in the controle valve where the thermocouple screws in has failed and needs replacing if your model will allow.
Sep 28, 2016 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
HOW DO I CONNECT MY AG DV 2000 TO MY COMPUTER SO WINDOWS CAN RECOGNIZE IT ?
http://service.us.panasonic.com/OPERMANPDF/OM_AG-DV2000.PDF
Service Centers
Eastern: One Panasonic Way, Panazip (2A-4) Secaucus, NJ 07094
(201)-348-7677 Fax (201)-348-7511
Southern: 1225 Northbrook Parkway, Suite #170, Suwanee, GA 30174
(770)-338-6855 Fax (770)-338-6656
Western: 4001 West Alameda Ave., Suite 100, Burbank, CA 91505
(818)-562-1579 Fax (818)-562-6663
Oct 02, 2014 | Panasonic AG-DV2000 Mini DV VCR
How to fix error code 50 on EFX 5.21i?
Precor Error 50, Too Much Brake (Magnet) Current Probable Cause 1. Shorted or damaged wiring between the lower PCA and the eddy current magnet is the most common cause for this error.
2. Bad eddy current magnet.
3. Bad lower PCA.
Corrective Action
  1. Thoroughly inspect the eddy current wiring and connections ensuring that the wires are not shorted to the frame or shorted together. Repair or replace damaged wiring as necessary.
  2. Disconnect the wires from the eddy current magnet. Using an ohm meter, check for approximately 100 ohms across the eddy current magnet terminals. If the reading is considerably low, replace the eddy current magnet. Measure ohms between each eddy current magnet terminal and the frame ground. You should have no resistance between the eddy current magnet terminal and the frame ground. If resistance is present this would indicate a partial short, replace the eddy current magnet.
  3. If the eddy current magnet wiring and the eddy current magnet are both good from the above tests, replace the lower PCA.
Error 50 Too Much Brake Current on Precor Cardio Equipment
May 22, 2014 | Precor Exercise & Fitness
Precor elliptical
3. Bad lower PCA.
Corrective Action
May 22, 2014 | Exercise & Fitness
Precor brake error 50
3. Bad lower PCA.
Corrective Action
Nov 26, 2013 | Exercise & Fitness
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
I have an Error message 50 coming up when iturn on my eliptical
3. Bad lower PCA.
Corrective Action
Jun 27, 2009 | Precor EFX 546i Elliptical Version 4
Manual for Delta Shopmaster 6" Jointer
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number. It will take you to another page and click on the first JT160 and when it changes screens click on the instruction manual, I had to click on it a couple times to open it but I did look at and it is about 48 pages long. Let me know if you have any problems and I will check further
Apr 04, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
