Question about Microwave Ovens
Our Magimix 11400 (less than 2 years old) heats normally, the vapour nozzle fonctions too, but our problem : when the coffee selection switch is put on the motors starts up, seems to fonction properly but after 3-4 seconds stops. On removing the coffee recipient we then noticed that no water had come through. We tried without the recipient and we could see that only 1-2 drips of hot water appeared.
    Scholar:
  • 157 Answers
Hello Pat, You have a common occurring problem. Your tubing in clotted. The least expensive solution is to use regular vinegar instead of water for several cycles, no coffee grounds. The clot will dissolve and water flow will return to normal. Cycle just water until no taste or smell of vinegar is present. Have some HOT COFFEE.
Posted on Oct 12, 2010
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
Doesnt always make a full cup of coffee sometimes it doesn't even make a cup. Machine i s less than a year old.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 18, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
Hi,My pressure cooker is not giving whistles.It is happening since two days.It had worked properly for the past 1 year.Safety valve is gud.I cleaned the pressure nozzle.There is not obstruction in pressure...
Take the vent apart and clean it in vinegar and water solution...there is mineral build up inside that stops it from whistling....
heatman101
Aug 27, 2010 | Microwave Ovens
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
GE microwv-doesn't heat, strong electrical smell, all else ok
The most common problem would be your magnetron. Check your purchase date, magnetron's usually have a five year warranty. Not a part I recomend trying to fix yourself (high voltage ).
Mar 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat.
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Dec 30, 2007 | Maytag UMV1152BAS Microwave Oven
How can it come on-but not really?
This is usually a bad door switch or door switch mount.
If it's less than one year old, it's under warranty and you should contact Frigidaire to get it fixed free.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We appreciate your thoughtful rating of our answer.
Nov 11, 2007 | Frigidaire FMV156DC Microwave Oven
Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
Aug 06, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
