I have transferred my card to another camera and now it needs formatting! help
    Problem Solver:
  • 9 Answers
Connect it to a computer through card reader....then go to my computer................right click on the drive icon and click on format start format...........
Posted on Oct 12, 2010
Hi there Aug 2010 I purchased a D90 - recently the transfer program has stopped working as it does not recognise any photos for transfer even though I can see them and transfer using other windows...
I've been studying the problem for several minutes and actually downloaded the manual from the Nikon site to confirm a suspicion. With the camera software denying the transfer yet other "Windows" application are makes me believe that there is or are corrupt files on the memory card.
The Nikon D90 is a "Semi-Pro" type camera and feature packed, however if you have been deleting files and not formatting then the memory card has become saturated with empty files (deleted) what needs to be done each time you down load is format the memory card. Formatting cleans off all the old empty files, restores the memory card to a fresh medium and allows the camera and cart to communicate between each other efficiently. Also one other thing that might have happened is that the protect lock has been engaged. The camera SD card has a lock protection switch on the left upper side (with the letter facing up) this little switch need to be pushed to the top edge towards the gold contacts. I'll supply a diagram, there is also another thing is this a new memory card? if so did you format the card to the camera before you used it? Also your camera has some SD card memory capacity restrictions these are shown on page 242 of your manual.
Diagram
Jan 10, 2011 | Nikon DSLR D90 Digital Camera
I have pictures stored on my camera and need to transfer them to my memory card. I cannot hook the camera up to the pc because I do not have a cord to transfer the images to pc. How do I transfer them onto...
Do not format!!!This will erase the card. Go into the menu and look for an entry for "copy" that will give you the option to copy the internal memory to a memory card.
Mar 27, 2010 | HP Photosmart M415 Digital Camera
My camera kodak easyshare C1013 cannot show pictures. it says "unrecognised file format"..i need help
The camera stores the pictures in a JPEG format only. You can use .jpg files in most image editing programs. Videos are stored in a .mov format that you can view with QUICKTIME software or KODAK Picture Software.
* What you can do is transfer the pictures to your computer and check the file format
* You can delete photo then just take a photo again.
Unrecognized file format means the file format of the picture in the camera is not JPEG or the memory card is faulty
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
Clean or format card error on Olympus XD card
There are most likely some "corrupted" images on your xD card. Very often a card reader "writes" data to the card while transferring or copying images into the computer. When you re-insert the card back into the camera, it doesn't recognize the new data (because it didn't create it), and gives the error, usually requiring a complete formatting be performed. There are also problems if you use a reader to rotate images, then re-install the card in the camera. The best way to accomplish what you were doing is to transfer the images into a folder on your computer, as the camera shot them (don't rotate them first). That way, you haven't altered any data on the card. For now, however, I suggest you format the card in the camera, so you can start with a "clean slate". Good luck.
May 02, 2009 | Olympus Stylus 850SW Digital Camera
Nikon coolpix L18. Can't put pix on comp. format card
I suggest you to remove the card from the camera and use a memory card reader to transfer the pictures to the computer. Note that the memory card should be formatted in the camera. Once the pictures are transferred you can reinsert the memory card to the camera and then format it in the camera.
Jan 15, 2009 | Nikon COOLPIX L18 Digital Camera
Suddenly unable to transfer photos into Nikon Picture Perfect
How are you transferring the photos? Are you using a cable, or a card reader? If you are using a cable then most likely the cable went bad. I have a D-1 and a D-2, and I never use the firewire cable. I put the CF cards into a card reader. If you are not using a card reader then try that. You can get a decent one from E-Film or from most any computer store.
One more step to try, did you format the card in the camera when you first loaded the card in? On my cameras you need to format that card to have them work with the camera.
Dec 16, 2008 | Nikon D40x Digital Camera
Memory card issue
First off what is the size of the mem card? Second did you make sure that you formatted the mem card with the camera before you tried to use it? What I would recommed is transfer your files to your computer FIRST. Then format the internal memory of the camera once you have transfered them over. Insert your memory card and then format the mem card. Turn the camera off and take your mem card out. Try taking a video. Turn off camera. Put mem card back in and see if you can transfer that video now and it should work.
May 02, 2008 | Casio Exilim EX-Z57 Digital Camera
Transfer of video from Panasonic NV-GS50 tape to computer
You can only transfer from the card to a PC. You can record video on the card in .mpeg4 format.
Oct 09, 2006 | Panasonic NV-GS50 Mini DV Digital...
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
