Question about Slik U-212DX Tripod
Need a rubber foot for a silk universal u 112
BERNINA ACTIVA 130 ADJUSTING UPPER TENSION FOR FINE SLIPPERY MATERIAL
Hope you have the owner's manual.
Sounds like your problem may have to do more with the amount of pressure the presser foot applies to the fabric. A lot of machines have a "pressure" adjustment so you would need to increase the pressure when sewing fine fabrics. You can also lay tissue paper (like the paper used for patterns or gift wrap) on the fabric which will help you control the fabric as you stitch.
As for tension, be sure you are using a fine sharp needle, like a 65 or 70 Microtex and a fine light weight thread. Using a different presser foot may be useful--perhaps a walking foot if you have one. Even using a single-hole needleplate may help. A looser top tension setting could prevent fabric puckering but so will adding tissue paper or fabric stabilizer.
Tips For Sewing Fine Fabrics
Sewing with Silk Slippy Fabrics
http://forums.threadsmagazine.com/gatherings/equipment-and-supplies/what-sewing-machine-silk-material
Apr 01, 2018 | Bernina Sewing Machines
How do I sew on a silky material. Does the tension need to be changed?
Generally, every time a project is changed, the machine may need to be tweaked. When sewing finer fabrics like chiffon, silk, the presser foot pressure needs to be adjusted, the needle should be smaller (and a fresh needle), the thread lighter weight, and the tension adjusted so the top & bobbin threads meet in the middle of the fabric. When sewing finer fabrics, the fabric will sometimes pucker. In that case, setting the stitch length shorter and possible adding paper (like tissue paper or fabric stabilizer) to the fabric sandwich will provide enough body to prevent the puckering.
Top 10 Tips for Sewing With Silk
How to Sew Silk
Jul 05, 2017 | Sewing Machines
My new machine sewed fine in cotton material, but I am having trouble sewing on a silky top.
Machine settings usually need to be re-adjusted when the project materials change, ie the needle size & type, the type/weight of thread, the presser foot pressure, the thread tension, the stitch length, etc. Sewing woven cotton is very different from sewing silk or chiffon. Test on scraps of the fabric before actually sewing on the garment. Even adding tissue paper to the stitching will help prevent fabric puckering.
How To Sew With Silk And Silklike Fabrics
My 880 is puckering when I stitch
Puckering is usually a result of incorrect tension, ie too tight. Be sure you are using a new needle and thread that are compatible with the fabric you are stitching. A heavier thread like Coats & Clark cotton-wrapped polyester may be too thick for sewing silk. Another thing you may want to check is the presser foot pressure adjustment (the amount of pressure the presser foot applies to the fabric and feed dogs). This should be discussed in your user's manual. Something else that may help is using a walking foot or teflon foot that allows the fabric to advance smoother, rather than the presser foot "pushing" the fabric as it advances through the machine.
Another thing that may be contributory is the type of fabric. Some fine fabrics, ie silk, chiffon, have a natural tendency to pucker.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiUx4uHqMnQAhVq0YMKHVGUDK0QFggfMAE&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Perfect Machine Tension Every Time Threads
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0ahUKEwicru-pqMnQAhWmxlQKHSuPBZwQFghDMAY&url=http%3A%2F%2Fwww.amefird.com%2Fwp-content%2Fuploads%2F2010%2F01%2FMinimizing-Seam-Puckering-2-5-10.pdf&usg=AFQjCNF6q0Pk13ZU4Hb3o3RiAGBbL04l-A&cad=rja
What is seam pucker Types of seam pucker with causes and remedies
Nov 27, 2016 | Sewing Machines
I have a Sewing Machine EURO PRO 416 I need a POWER CORD WITH FOOT CONTROL and RUBBER RING LOCK
Check this site
Euro Pro Sewing Serger Machine Parts www drdanessmh com
It is impossible to list all parts on a webpage so if you don't see the part you need click their Contact Policy Tab at Dr. Dane's Sewing Machine Hospital for more Parts
Jul 27, 2015 | Euro-Pro 416 Mechanical Sewing Machine
Thread keeps breaking, Silk Fabric bunching u[
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
Most machines can use generic Schmetz needles. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric. make sure the correct needle for silk is being used.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
also clean under the needle plate & in the bobbin area for lint or loose
threads
check to make sure the feed dogs are completely in the up position
if none of these suggestions work then it's possible that the machine
is out of time & would have to retimed at a sewing machine shop
Apr 15, 2012 | Necchi 4595 Mechanical Sewing Machine
My singer HD 110 will sew a bit then suddenly the needle will slow down to a stop & the handwheel seems stuck, yet the motor is still running.
Hello there! Make sure your pattern selector is compatible with the presser foot. Good idea to test with a straight stitch setting: Tension: 4. Width:4-5. Length 5 after you insert a new needle and re-thread machine. Your previous needle may have become bent when machine malfunctioned. Use fabric compatible with needle size. Always raise presser foot when threading! Then always lower presser foot before sewing. Remember to use blue tip scarf needles with synthetic fabric silk thread 50. Purster thread 50, mercerized cotton thread 50-60; #11 or #9 for fine or lightweight fabric with silk thread 50 or fine Pollyester thread; #18 leather needle for leather, #14 - 16 denim . Jimmy Sweep out shuttle carefully with small brush for broken threads and lint.
Mar 31, 2012 | Singer Sewing Machines
Universal remote I need the code to a Sharp TV
Hello
Three digit universal remote code for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four difit universal remote code for Sharp tv are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power ON/OFF switch each time before trying an other code.
Mar 01, 2011 | Televison & Video
I dont have the manuals to my philips universal remote so i need to add componts dvd
Try this link, http://www.universal-remote.net/philipsmagnavox.html
or instructions are as follows - Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
4. With your device on, press CHANNEL Up. If the
equipment, try one of the other codes for your
brand.
TV
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
Jul 03, 2010 | Philips Televison & Video
Sewing very fine silk
You can try adjusting your stitch length this may solve the problem right away.
It could be the thread your using, I have had to switch threads before. Rewind your bobin, sometimes issues can occur by a poorly wound bobin.
You can also try to use a different foot (my machine comes with a satin stitch foot)and or slow the speed of your feed dog.
Sometimes a very fabric does need some sort of backing, a tear away, or wash away might be your only answer.
I hope this helped.
Jan 24, 2009 | Elna Sewing Machines
Slik U-212DX Tripod Logo
161 people viewed this question
Top Slik Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Slik Photography Expert? Answer questions, earn points and help others
