Question about Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor
Hi, the monitor suddenly turns a very green/yellow hue and is doing it more regularly now, it sometimes just as quickly goes back to normal. Any ideas? thanks
  • 11,361 Answers
It can be the cable, please check all the pins at both ends and make sure they fit tightly to the connector at the monitor and at the PC, it can be the video card rpblem also so you need to try this monitor with other PC.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 12, 2010
Testimonial: "Perfect! Ok, i feel like an idiot for making sure the cable was tightened up first, but hey, thanks!!"
My background on my screen recently developed a purple hue to it, instead of a white. Can this be corrected?
This is likley a problem with the monitor's signal cable. Try moving the cable around steadily and see if the color suddenly goes back to normal or changes to a yellow hue. If this is the case and you are able to remove both ends of the cable then a replacement can easily be purchased from a local computer store or online. (Try www.amazon.com or www.monoprice.com).
Mar 17, 2011 | IBM ThinkVision L170 17" LCD Monitor
There is a sudden change in the hue of my lcd- acer aspire 4740
It can be an issue with the display cable or the LCD panel itself.
U will have to check with a local tech.
May 31, 2010 | Acer Aspire 4720 Notebook
It went this greenish yellow hue
Try resetting the monitor to defaults if possible. If you still have the greenish yellow hue then at that point, try another known working monitor on the computer, if the hue goes away then you know the original monitor is bad, if you still have the greenish yellow hue then you know the video card is bad.
Aug 19, 2009 | Kogi L7CH Monitor
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Dell UltraSharp 1702FP 17" Flat Panel LCD Monitor Logo
151 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
