Question about Mastercool 67680 Evaporative Cooler Air Conditioner
I have an updraft evaporative cooler. I get a lot of white flakes coming through my vents. Looks like hard water calcium flakes. How do I resolve this issue?
  • 40 Answers
Clean and service the cooler. remove the filters and gently wash them with a garden hose. isolate the power to the unit and wipe components with a damp cloth
Posted on Apr 04, 2011
Is there a anti-calc tablet or something for de-scaling the HIN 172 ?
Run a tablespoonful of white vinegar through the iron to remove calcium deposits and then use de ionised water from then on to avoid it happening again.
May 19, 2017 | Irons
I cannot get my coffeemaker to brew. Do i need to replace filter before it will brew, or clean with vinegar?
Run a couple cups of white vinegar through it (just like you were making coffee). Don't use a filter. You can use the same vinegar over again if necessary.
If calcium build-up is the problem, you will see lots of little flakes in the used vinegar. Continue running vinegar through it until you are sure the flakes have stopped, then run a couple full pots of water through it before you try making coffee.
Mar 10, 2015 | Coffeemaker Coffee Makers & Espresso...
My husband and I recently purchased a new home with all new appliances, and a water softner, but recently we have noticed white flakes coming out of our ice maker...any suggestions on what this maybe...
check the operation of the water softener as the flakes may be calcium deposits. Use only kiln dried softener salt in the unit as pool salt has impurities that will damage the filter medium
May 06, 2013 | Refrigerators
I have a white powdery substance coming out of the steam vents of my Rowenta iron. How do I get rid of this stuff?
The iron has white flakes coming from the steam vents.
The white flakes can be caused by calcium or other minerals in the tap water. To solve this problem, switch to bottled spring water. Once the water is changed it may take several uses before your iron adjusts to the new mixture and the issue is corrected.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Rowenta Vacuums
Bought used - want to prevent rusting of water trough and other
If you can get to the whole water trough to coat it, I recommend you get some spray undercoating or a product like "Phil Swift" promotes on TV and spray it on the affected area.
Mar 29, 2017 | Mastercool 67680 Evaporative Cooler Air...
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Evaporative cooler not getting water from water line
The pump is probably gone. the way it works is a float allows the water level to stay the same in the reservoir so check that. Water is pumped up to the hoghair and trickles down into it. A big old blower pulls the wet outside air into the room. We call that one a swamp cooler down here on the gulf. Go outside and spray some water on the unit to cool down the house till you can get the pump replaced.
May 10, 2009 | Heating & Cooling
Flakes of stuff in spray head
clean the tank with white vinegar
pour it in and wait 15 mins, than pour 4 or 5 pots of water thru it
Nov 18, 2008 | Bunn NHB Coffee Maker
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
423 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
