Question about D-Link Xtreme N DIR-655 Wireless Router
I am unable to open my nat on my Dlink-Dir 655. I have a static IP configured but am still unable to open Nat. Help.
    Problem Solver:
  • 18 Answers
Thanks for posting your problem with fixya.
I understood your issue and I would request you to follow the below steps 1. Type in 192.168.2.1 on your web browser. 2. At Router's login page, type your username and password(Default Username: admin Password: (blank) ).[ Contact DLINK customer support for details. Toll free number on products box] 3.Once you are in, browse the different tabs and look for UPnP 4.Save and test your XBL connection.
If no go, I would request you to follow the steps on this link. It would be really helpful for you. http://www.mlgpro.com/forum/showthread.php?t=137247
Great time. I appreciate your feedback.
Posted on Oct 12, 2010
I can't change the nat type for ps3 or call of duty black ops how do i change the nat type
When you do a connection test on your PS3, what NAT type shows up; 1, 2, or 3. If you're worried about the STRICT NAT type in Black Ops, don't worry about it, the problem is the game and not your router.
http://forums.dlink.com/index.php?action=printpage;topic=21218.0
Feb 06, 2011 | D-Link Xtreme N DIR-655 Wireless Router
How can I set up static IP addresses for my router and all my gadgets?
I don't know which version you have, go to this link and it will walk you through setup and configuration.
If your still stuck let me know.
http://www.dlink.com/products/default.aspx?pid=DIR-655&tab=3
Dec 21, 2010 | D-Link Xtreme N DIR-655 Wireless Router
How do i access the NAT settings for my D-Link DIR-655 Router. i believe the strict setting is affecting the WiFi i need to connect to the internet through my computer.
NAT STRICT
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Xbox/PS3/Wii in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Regards
TOM
Oct 24, 2010 | D-Link DIR-655 Wireless Router
Dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Jan 04, 2010 | NetGear DGN2000-100NAS Router
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
D-Link Xtreme N  DIR-655 Wireless Router Logo
638 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
