Question about Aprilaire 550 Humidifier
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The intake water line is attached to the hot water line in the water heater. I have a Aprilaire humidifier, Model 560.
  • 455 Answers
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Posted on Oct 12, 2010
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
2 months into the heating season I noticed a large puddle around my heater. the Aprilaire 600 unit was leaking. The distrution tray had a red substance around the water holes. Also the overflow drain line...
Mold can really cause problems with humidifiers-
They do need to be serviced, cleaned up, and something like weak bleach used to kill mold spores, -- get it all tidy and clean!
Were you able to clean out the drain line?-- and is it draining now?
And is the float valve shutting off the water flow, before it reaches the overflow drain pipe?
Another concern would be the soaking pad-- Has it been changed recently?
Tell us more--
Mack B
Jan 06, 2011 | Aprilaire 600 Humidifier
There is no water reaching my AprilAire humidifier, indeed no water is flowing through the saddle valve attached to the hot water pipe of the hot water heater. Considering what would be involved in...
Yes a new valve seems in order. and yes having the valve on the cold side would create less build up in the filter pad so long as your water dose not come in at 37 degrees. but, I think you have it right.
Dec 22, 2010 | Aprilaire 550 Humidifier
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
I am getting a white scale or powdry dust throughout the house. What is happening?
You need to replace you humidifier pad. The water scales up on the pad and this is the white powdery substance you are getting.
Feb 02, 2010 | Aprilaire 550 Humidifier
The unit leaks water on the floor
you need to replace the pad every season. if you are using a generic pad maybe more often. it also must be level and the drain coming off bottom clear. i suggest getting pads from aprilaire.com . not the generic from hardware store. also if its got a black feed tube going from the solinoid valve to the top of the humidifier pad you may want to replace that aswell, they have been known to crack the new ones are grey.
Aug 10, 2009 | Aprilaire 700 Humidifier
Aprilaire evaporator screen produces a white runoff to the sump pump which clogs causing it to jam. are there uncoded evaporators?
replace the AA#35 water panel annually also try poring a touch of bleach where the pump is the pads have the coating to keep them from rusting you miht be able to find a generic paper model if you look at your local department store
Jul 13, 2009 | Aprilaire 600 Humidifier
No water flow to the humififier
I've been working on the Aprilaire 110 unit today, after encountering the same problem. Here's how I fixed it: First, with the humidistat turned to 0%, I turned off the water supply saddle valve all the way (all the way to the right)--and then turned it back on all the way (all the way left). Still no water flow. Second, I slightly loosened the inline valve nut on the discharge side of the solenoid on the side of the 110 unit. Water began flowing, so I tightened it back up; and now the water flows freely. Conclusion: You may have some mineral deposit buildup in your lines, as I apparently did.
Nov 25, 2008 | Aprilaire 600 Humidifier
Aprilaire 550 Humidifier Logo
391 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
