Question about Samsung Washing Machines
Washer J14535 comes up with 4E error but there is no problem with the water feed all filters are clean and wastpipe is not blocked any advice?
There is problem with inbuilt water filter which is get choked,which is located inside water valve where inlet pipe attaches.remove inlet pipe from inlet valve by hand,remove filter inside the valve clean & refix it check the pressure in detergent box
Posted on Jun 08, 2008
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
a. Check for Kinks.
b. Check for Clogs.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
Machine operates, then has a 4E error message
The 4E error means that the washer is having a problem with the incoming water. First, check that your shut-off valves are open. Next check your washer hose connection filters for anything blocking the flow. (There are filters inside the connection at the washer and there should be filters at the shut-offs.) Clean the filters, if needed. Make sure that the water is flowing properly (no kinks in the hoses). Also, open the valves and let the water flow into a bucket. Check the flow rate; it needs to be sufficient to fill the washer in under 8 minutes.
Next, try new hoses. (Some hoses will detect leaks and close themselves off.) If that doesn't solve the problem, check that your washer drain hose outlet is not below the level up to which the washer should fill.
If that doesn't help, the inlet valve might be bad. The other possibility is an problem with the reed switch or air line to the flow sensor is leaking.
I hope this helps.
Aug 25, 2014 | Samsung Washing Machines
2008 Samsung front end loader develops a 4E error
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Error 4E + timer countdown is delaying
Sep 02, 2009 | Samsung WF337AA Front Load Washer
4E error....samsung J845
Aug 23, 2009 | Samsung WF203ANW Front Load Washer
My 7kg samsung washer always flashes error code 4E now... please give me the solution...
Jul 04, 2009 | Electrolux EW1200i Front Load Washer /...
My samsung washing machiene keeps coming up with the error 4e. what does this mean?
Mar 15, 2009 | Samsung WF337AA Front Load Washer
Samsung washer
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
208 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
