Question about Lexmark Office Equipment & Supplies
Hi Just printing photos,12 printed,then a notice comes on computer,printer not connected ,spool not running the printer is a x3550 registration receipt dated 30/08/2007 Regards Ken
Hi I deleted the printer program from computer
and reprogramed,and it worked just fine
Ken
Posted on Jun 03, 2008
The print spooler service is not running iam using MP830 printer
There are a few different causes for this. All of them leading to the "spooler" service to stop running.
The most common remedy is to just reboot the computer. If this fails, there may be a corrupted document in the spool queue that is crashing the service repeatedly here are the steps to clear it out:
For Windows XP (your computer says "start" in the bottom left)
1. Go to the "Start" menu and click "run"
2. in the window that comes up enter "net start spooler"
3. Try printing again.
4. If the problem continues then:
5. Click "start" and "Run" again.
6. enter "C:\Windows\System32\spool\PRINTERS" and click ok and delete any items in there.
7. Close that window.
8. Restart the computer.
You should now be able to print.
For Windows Vista or Windows 7:
1. Click the blue "Start" orb
2. In the search box enter "command"
3. The computer will return with several items
4. Right click on the black item that says "command prompt"
5. click "run as administrator"
6. in the black window type "net start spooler" and press enter
7. try printing again, if it fails continue to step 8
8. open the blue start orb
9. in the search box enter "C:\Windows\System32\spool\PRINTERS"
9.5. If you get a permissions message click continue
10. delete all items from there.
11. back in the black command prompt box, type "net start spooler" again
12. You should be able to print.
If you still cannot print, you may have one or more corrupted print drivers. In this case you will need to delete and re-install your printers from the computer using instructions from the manufacturer.
May 02, 2011 | Canon MP830 All-In-One Printer
My printer doesn't work as it should be beacause i tried to print a page, i pressed ok but it didn't come out
Hi Bianca!
What you should do is to clear the print spooler - the printer queue. If you're using windows, right click on my computer and then press in "Manage", in the opened window go to "Services and Applications" and then "Services". go down the alphabetical list in the right window pane until you come to the service with the name "Print Spooler". Right-click this entry, then select "stop". This will stop the service that holds your print queues. Leave this window open, press on start and then type "spool" in the search bar (or in the "Run" command line if it's windows xp) and press enter. In the opened window, go to a folder named "PRINTERS", and Delete every file within this folder to empty the jammed print queue (pressing the "ctrl" and "a" keys will select all files and then you can just
hit "delete"). Close the explorer window now that we have emptied the cleared spool files, and return to your Services window. we must re-start the Print spool service, and do so by right-clicking the Print Spool entry and selecting "Start" from the list. Close the services window and try printing again. It should work now. Good luck!
Jan 10, 2011 | Lexmark Z617 InkJet Photo Printer
I have a Lexmark X3550 printer and need a wireless adapter card, but cannot find this anywhere since Lexmark no longer carries this part. Is there another wireless adapter card that would be compatable...
Try E-Bay, you might be lucky.
Failing that, you can try using a LAN print server, connect the printer to the print server and connect the printer server to your LAN.
Then any computers on your LAN can print to this printer.
OR
Connect the printer to your computer and set it up as a shared printer and if your computer is connected to the LAN then any computer can print to this printer provided you computer and printer are switched on.
Sep 18, 2010 | Lexmark X3550 All-In-One Printer
I have had this printer for over a year and it has worked flawlessly until about 3 weeks ago and now it takes about 2 minutes after I click on print for the printer to activate. Any suggestions?
If your X3550 prints OK when it does start, perhaps the selection for printing immediately when receiving a print job has been changed to printing after entire print job has spooled.
This selection can usually be toggled between these two choices.
Jan 14, 2010 | Lexmark X3550 All-In-One Printer
Message saying "no connection between PC and printer. Installed new USB cable and it works for 2 weeks, then "no connection notice again". Uninstalled and reinstalled Dell printer software and no help.
hi jaromarburge,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 12, 2009 | Dell 922 All-In-One InkJet Printer
Able to print documents on HPc4385, but cannot print photos
When you were connected with a USB cable was it connected to the computer your using as local? Are you using a wirless print server? Possible corrections are in the properties of your print setup. You can change the spooling properties to print immediately to require less memory.
Aug 30, 2009 | HP PhotoSmart C4385 All-in-One Printer
My Dell Photo Printer 720 has stopped printed, no response at all to print jobs. I have unplugged the printer, no change. I have rebooted the computer, no change.
hi there,
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
Aug 03, 2009 | Dell Inkjet 720 Printer
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
Printer says cartridges full, computer says cartridges empty even though i have bought and installed new cartridges
Printer connection had come out of the computer port and I hadn't noticed, printer itself is stand alone so was printing photos OK but I couldn't print documents. Everything up and running once again and both printer and computer say cartridges are full.
Aug 17, 2008 | Kodak Office Equipment & Supplies
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
