Question about Sony MBX-49 ASSY Motherboard
Pcg-f 807. The problem is no display(back light ok).External monitor display ok. What is the problem? is any relation to cmos battery. Thanks in advance
3 Suggested Answers
exspert
  • 55 Answers
SOURCE: no display on my sony vaio :-(
ok " try going into control panel , find monitor and click on it
go into advanced setting and see if you can reset it.
also : there is a thin cable that runs from the computer to the screen , it may have to be replaced if worn or broken.
Posted on Jan 21, 2008
multilinkent
  • 739 Answers
SOURCE: No Display on Mother Board
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Posted on Jul 21, 2010
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
SONY PCG-691N HOW CAN I REMOVE BIOS PASWORD
Welcome to FixYa!
Are you the one who set up the BIOS password? If not, unfortunately, there's no way for us to retrieved the password. The only way you can reset the password to default settings is to reseat the CMOS battery on the motherboard, its a circular thing that looks like a battery of a watch,sometimes a pin hold it, just detached it then wait for at least 30 minutes then connect it back again,
Note: Before you reseat the CMOS battery,make sure that everything is unplugged on the computer, like AC adapter,battery and all external devices...
Hope this will help...Thank you for using Fixya...
Jul 04, 2011 | Sony VAIO PCG Notebook
My laptop comes on, and the screen stays blank, (black ) nothing, I tried hooking up an external monitor but it does nothing also, could the invertor be the cause? Unit is a Sony VAIO PCG-TR3A
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
Dec 09, 2010 | Sony VAIO PCG-TR3AP1 Notebook
The screen is black but the computer is running,
Try to hook up with external monitor in order to check if your lcd monitor have problem. If the external monitor have display that means your lcd monitor is defective. If the external monitor having no display in that case you have to check your system ram or memory or clearing your bios or cmos by removing your cmos battery for 5 seconds then insert again the battery. Then try again turn on your computer. Good Day
Nov 30, 2010 | Toshiba Satellite A215-S5837 Notebook
Hi there i have a sony viao laptop pcg-7121m, there is no power to the display so when i switch on the laptop the power button lights up but there the screen stays blank, how can i try and trace back the...
Try holding down the function button on the keyboard and tap the F key with the (O) symbol above it, Its the symbol for monitor. You may have to press them a few times. That will toggle computer from its external only monitor mode. If not then hook up an external monitor to the computers vga jack and try again. If you get the external monitor to work that way and not the built on display then the built on display will need replacing and if it does not go to working at all then its most likely a motherboard issue. If the external display does work then you can continue to use it that way until you get the screen repaired/replaced.
Aug 25, 2010 | Computers & Internet
No display on screen but lights on keyboard. The battery and power lights come on and the hard disk light blinks, but there is no display on the screen
Try an external monitor on the laptops vga output, if the external monitor works ok then you have either a faulty screen or inverter
Apr 05, 2010 | Toshiba Satellite A135-S4527 Notebook
Sony Vaio PCG-9J3M - where is the CMOS battery located?
You can find CMOS cell on motherbord chipset.
it is in back side of laptop.
Open back side of laptop then find motherbord chipset you can find 1 CMOS cell on motherbord chipset pull that CMOS cell for 15 minutes then all settings are defaults.
Aug 13, 2009 | Sony VAIO FX150K Notebook
No display on my sony vaio :-(
Jan 20, 2008 | Sony MBX-49 ASSY Motherboard
Pcg-xg28 no display
Either the video card is bad, or the memory is bad. Replace the memory first to see if that fixes the problem. Also, if capable, reseat the CPU, which is located beneath the Keyboard.
http://www.Computer-Repair-Today.com
Nov 28, 2007 | Sony PCG-FR130 Notebook
Sony Viao Display Problem
Sounds like you have some internal issues going on with this Laptop! If you are getting the same response when you connect an external monitor, then you more than likely have a few things going on here: A bad VGA port for starters, Issues with the Data card, and your graphic card is cetainly not helping. In addition you may want to check appropriate drivers as they are sometimes updated! But my best guess is that you are having issues internally! That could be costly! Sorry!
Nov 26, 2007 | Sony PCG-FR130 Notebook
Computers & Internet Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
