Question about Frigidaire Refrigerators
I have a Frigidaire upright freezer that is leaking out the bottom of the unit onto the floor.......It is running fine and freezing fine.....I thought it was out of level, and it was, but I did level it out yesterday and now, there's water again, on the floor under the door.
    Genius:
  • 1,122 Answers
Yout drain in the frig. is clogged,find the drain reservoir most times in the back top of frig. remove cover and clear it out with a hanger or shop vac,if ice is there melt it with hair dryer then claer out,hope this helps,thanks-mike
Posted on Jun 01, 2008
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire refrigerator/freezer
bit confuse with your problem.. are you having a defrost issue or leaking issue? If defrost issue... Check your compressor it is working? compressor - The thing that make noise behind the refrigerator...
Sep 05, 2007 | Refrigerators
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Frigidaire FRS26ZNH frig is freezing water in the bottom of the freezer and is leaking water onto the floor. i have looked for a stopped up drain plug or hole with no success. please help. john
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Frigidaire Refrigerators
Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire FRS26R4A Side by Side...
Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Jan 11, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Refrigerators Logo
807 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
