Question about Whirlpool Duet GHW9150P Front Load Washer
F 28 error code - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Posted on Oct 12, 2010
How can i solve error code28
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Feb 09, 2013 | Samsung R530 Notebook
Device driver codec 28
Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your bios. If that's the case, a reboot might fix the Code 28.
You might have to visit your computer or hardware manufactures homepage and download the driver for the device.
Good luck
Nov 01, 2012 | Computers & Internet
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
Error code 28
Error code 28 could be caused by corrupt drivers, a registry error, or hardware issues.
http://www.optimize-your-pc.com/regcure/regcure_blog/2010/03/14/how-to-indentify-and-fix-error-code-28/
This site should give you the viable information you need to fix the issue
Jun 16, 2011 | Microsoft Windows XP Professional
Mar 01, 2011 | HP Computers & Internet
The drivers for this device are not installed. (Code 28).How to resolve it?
More info and resolution to this error code can be found here
Sep 27, 2010 | Microsoft Windows XP Professional
Hello, my wireless is not showing on my computer and when i go on device manager on my computer it has a question mark on ethernet controller and say erro code 28, how can i fix this?
Do your Wireless Device (PCI or USB unit) comes with an installation CD? If so, use the CD to install the software/drivers.(Instead of using the Windows wizard). Remove any previous installation before reinstalling with the CD.
Resit your device to a different USB port or PCI slot. If the drivers/software are properly installed, windows will detect and installed the device correctly.
Cause of the Code 28 Error (In general)
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are several of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
1.Restart your computer if you haven't done so already.
2.Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
•Remove or reconfigure the newly installed device.
•Roll back the driver to the version prior to your update.
•Use System Restore to undo recent Device Manager changes.
3.Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Important: Make sure you install the drivers for the correct operating system. Example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Most Code 28 errors are caused by updating or install the wrong drivers for a device.
4.Update your OS to latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
**Note: Certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
5.Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. Not recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Hope it helps.
Aug 22, 2010 | Microsoft Windows XP Professional
Driver installation error code 28 inf error
im receiving a error inf 28 on my mp3 sony walkman nwz-e344
Apr 25, 2010 | Sony Walkman Video NWZ-A816 Digital Media...
Whirlpool Duet GHW9150P Front Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
