Question about Panasonic Strada CN-NVD905U GPS Receiver
Where can I find the aux in and out harness for my radio. I need it to install other items. Please help!
What do I need to add a AUX port into my 2004 Ford Freestar? It has a AUX button on the front of the radio but there's is no port.
http://www.installer.com/item/display_item.php?it=is75
Install a aux add on harness open the link an it will provide you with what you need
Feb 07, 2015 | Ford Cars & Trucks
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
AUX stopped working
Take it into a auto electric shop to be check out, It could be loose wires or a short in the wireing, Some where,
Nov 27, 2012 | Kia Cars & Trucks
Does a 2002 Altima have an AUX connection?
No, but some of the stock radios have a DIN connector in the back that allows you to plug in a harness and switch that will provide the aux input. The radios are not that hard to find on EBAY, I bought one for $20. but I have not built the harness yet. There is info all over the net if you google: Altima DIN aux.
Sep 16, 2011 | 2002 Nissan Altima
2005 chevy cavalier after market radio has no power, im installing a pioneer head unit in my car, i bought a wairing harness connected it to the wiring harness for the new radio, im getting power to the...
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Sep 03, 2011 | Car Audio & Video
Hi all i have a jeep grand cherokee 3.0 crd 2006 model it does not come with an AUX input jack for the radio. how can i go about installing one or should i say can this be done. nb this is the south...
Check center console to be sure there isn't a aux port in there if not the best thing to do it find a Junk yard and find your yr model with one and get it
Oct 25, 2017 | Cherokee Jeep Grand 2005-2007...
Have 2003 monte carlo aux input cutting out
If the radio itself works all the time then you probably have a bad connection between the aux device and the radio. It could be a cable, or it could be the jack. Depending on that it is in easy fix or a harder one. You can take it to a place that installs car stereo equipment and have them look at it or just tackle it yourself. If you put in an aftermarket radio you will need a wiring harness and possibly an antenna adapter. Sometimes you need other things that interface between the car and the harness as well such as controls for steering wheel remotes and other special items.
Jul 27, 2009 | Car Audio & Video
How do you install the frd03-dvd? mines came with no instructions.
Hello jeffery_armi,
The FRD03-DVD allows you to replace the factory head-unit and retain the audio and power to your OEM DVD player. With the FRD03-DVD, the audio from the OEM DVD player is connected to the auxiliary input of the aftermarket radio to allow the DVD audio to be heard over the vehicle's audio system.
The FRD03-DVD harness consists of a molex-plug, stereo RCA audio male connectors, and red and black wires ending in "pigtails".
1) Connect the molex plug into the OEM harness.
2) Connect the RCA audio connectors into the "AUX" inputs of your aftermarket head unit.
3) Tap the red "pigtail" wire into the "accessory" lead of the vehicle radio harness (also usually red).
4) Tap the black "pigtail" wire into the "ground" lead of the vehicle radio harness (also usually black). Alternatively, the black wire may be terminated with a ring terminal and secured to a metallic ground nearby.
Hope this helps.
May 13, 2009 | Pie Frd03 Aux/S
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Panasonic Strada CN-NVD905U GPS Receiver Logo
Top Panasonic GPS Experts
skybluehon
Level 1 Expert
steve morris
steve morris
Are you a Panasonic GPS Expert? Answer questions, earn points and help others
