Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Where can I find carburator adjustment and hose replacement instructions/diagram
  • 7,733 Answers
HERE.
Posted on Oct 14, 2010
Schematic for hoses on carburator on a 1985 buick century
Here is the diagram for the 3.0 V6 engine which I assume you have.
Courtesy autozone.com
Apr 09, 2013 | 1985 Buick Century
Mitsubishi vacuum diagram
hello
please answer me to khalajy2@yahoo.com
i have mitsubishi lancer with 4G13 motor and sndlw body (1992 year)
the carburator is single(is not electrical) the all hoses are moved and i dont now how to fixe them please help me for a plan or map of hoses of carburator(i am teacher in iran i can buy a lancer 1992 after 29 year teaching do you beleave this this is iran)
thanks
Aug 04, 2012 | Mitsubishi Cars & Trucks
Gas shooting out of rubber hose above carburator. craftsman lt200 with kohler engine.
If hose coming off carburator does not connect to anything then it is the over flow for carburator when float gets stuck and does not close needle valve causing excess fuel in carburator bowl and is drained automatically through vent orfice connected to hose that gas is dripping from. If this is the case then remove carburator bowl, check float, needle valve and o-ring in where needle valve goes. sometimes when carburators sit over winter with gas in them the gas breaks down and over time will gel/harden and cause float to hang up and o-ring for needle valve to deteriate and not sealing properly. clean and replace parts as nessesary.
I hope this helped.
Oct 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Carb is leaking it looks like accelerator pump. truck still runs not sure if there is a gasket i could replace.
Hi!!
There is a carburator rebuild kit that you can get at the AutoParts store for your vehicle. Runs about $25 and it has a diagram and step by step instruccions on how to rebuild the carburator yourself. If you don't feel comfrortable doing it, take it to a carburator shop for rebuilding. It is cheaper if you take the carb. by itself. Before removing carb. take a few pictures of the hoses and linkage n mark each hose and electrical connection removed, this will make your life a lot easier when you install it back.
Don't forget to rate this answer, Good Luck.
Apr 27, 2010 | 1986 Dodge Ram 50
We need a picture of how to replace carburator and hoses
any chilstons or haynes manual will have a diagram
Aug 23, 2009 | 1983 Toyota Pickup
1989 accord lx, idles high at start-up, now it won't stay running
Carburated engines of that year may have an idle screw adjuster. You can see the screw from the outside of the carb. If so, try adjusting the carburator with a screwdriver. Unlike fuel injected Engines they can be manually adjusted.
Apr 08, 2009 | 1991 Honda Accord
Engine will turn over but will not continue to run
the fuel filter is in the tank on top of petcock that bike has a vacum operated petcock(fuelvalve)if the vacum hose is bad no fuel flow check the back of the fuel valve for a small hose that goes to the manifold make sure it is good put vacum on the hose wile hooked to the fuel valve and make sure that gas runs out of the hose give me a rate please hope this helps
Dec 13, 2008 | 1997 Honda VF 750 C Magna
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
42 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
