Question about Hobart Microwave Ovens
What does error 7 stand for on an ecomax CHH50 pass through machine
How to change bulb
First you get a person to stand on a chair and hold onto the bulb, then you get another person to turn the chair with the person standing on it, after about 7 turns the bulb should come out. Be sure to turn clockwise when looking down at the floor. Cheers.
Jan 18, 2015 | Microwave Ovens
Symbol ol a key will not allow a wash cycle
This indicates that the DOOR SWITCH is faulty and is not contacting without which the machine will not start off as it encounters an error for safety.
You can remove the door switch clean and reset it or else replacement is the best option.
Check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Sep 23, 2011 | Microwave Ovens
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
What is the se code that comes up on the oven, and it wount work? How can we fix this error code?
Hi longislandlu,
SE stands for "Sensor Error". This appears if the keypad is held down for longer than 10 seconds but if not held down this means that your humidity sensor has shorted and needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Mar 31, 2011 | Samsung SMH9187ST Microwave Oven
Error code SE on Maytag Microwave
The error code SE stands for " Systems Error " which indicates there is a short in the keypad membrane causing the system to lock up. The only option is to have the keypad replaced for normal operation.
Mar 27, 2011 | Maytag Appliances Over-the-Range Microwave...
Our microwave has an error code -SE- and will not work what is this and how do we fix it.
Hi wmp_44,
Hope this helps.
Feb 18, 2011 | Samsung SMH7174BC Microwave Oven
Pigeon Induction Error E6 occurs
E6 stands for 'Internal Electronic Temperature is higher than normal for 3 seconds', contact service centre.Source: Prestige Induction Error Codes
Feb 16, 2011 | Microwave Ovens
Water will not pass through the capsule?
Try running vinegar in stead of water, without the coffee thru it several times.
Dec 27, 2009 | Microwave Ovens
Error C5 and large noise in Amana RC22
hi my name is mark, that code stands for current sense.CS the following is a list of the possable things it could be. 1. interlock sw. 2.open thermal cut-out 3.open/loose wire 4.power relay 5.H.V. board 6.diode 7. magnetron 8.capacitor 9.transformer 10.triac it is worth fixing. RC22s are very expensive ovens if you need part #s i will need the serial # and P# [P132....M] to get correct parts. hope this helps. thaks for your question.
Mar 06, 2009 | Amana RC22S 2200 Watts Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Hobart Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Hobart Microwave Oven Expert? Answer questions, earn points and help others
