Question about Dishwashers
The water is not going out of dishwasher, it seems somewhere is clogged.
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 12, 2010
Dishwasher won't drain. runs through normal cycles, and then just stops still full of water on the bottom. I have taken it apart and can't see any obstructions.
is there a clog in the hose somewhere because when ours clogged it would not drain it just kept circulating water all over the clean dishes and it was gross
Jan 03, 2011 | Frigidaire 24 in. FDB635RF Built-in...
Kitchen Aid Model KUDT03FTSS2 -- no water getting into dishwasher. I have no idea what to check to see if there is a clog somewhere.
Make sure the water tap into the sink hot water plumbing has not been turned off. Check the routing of the water line which feeds the washer to look for kinks somewhere. The inlet water solenoid in the washer base may have failed--if no click when water should go in, suspect the solenoid. It is a fairly simple thing to replace. The last suspect would be a failure of part of the control system that signals the inlet solenoid. Hope this helps!
Nov 13, 2010 | KitchenAid Architect® KUDT03FT 24 in...
I have an LG ldf7811st dishwasher. My bottom arm spins with water, my middle arm does not spin but does have water coming out, and my top arm doesn't spin or have water. I have just finished taking apart...
I'm thinking like you're thinking, that it's something affecting the water pressure, but you've done everything in the upper section, so the problem must be from below, unless you have a leak somewhere you haven't noticed and are losing pressure because of that, or a faulty clamp maybe. Also, maybe obstruction, but that seems unlikely unless your water is high alkaline content, etc. Maybe see if any neighbors have had any similar problems, that would verify the water pressure question, hopefully. All I can suggest without seeing it, sorry.
Mar 25, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Water not pumping out spray arms.
clog in the arm. It should spin due to water flow.
Remove the arm. Usually a tow part arm (top and bottom). Or a central screw with cover plate.
Look for a clog and remove.
If a central arm in the middle of the machine the clog can be in the pipe supplying the water. Again take apart and look for a clog.
They are not belt or gear driven. Simple water driven parts only. If the water is flowing and not leaking under the machine you should be OK with a simple clog somewhere.
Mar 07, 2010 | Kenmore 24 in. 17283 Built-in Dishwasher
Water not draining
You need to access to the drain hose, located under the bottom panel, and check that this is not clogged, if you do not find anything in there, check that the connection to the drain line outside the machine is not clogged.
If still no luck, then check that the drain pump is not faulty, that is possible.
You can find schematics and replacement parts by entering model number here.
Feb 18, 2009 | Frigidaire Dishwashers
BF41 Dishwasher with a leak stuck in mid cycle
Your air gap is clogged, the thing sticking up from the sink next to the faucet. there is a hose that goes from the air gap to the dishwasher, somewhere in that system is clogged. You can clear it if you have a quarter inch drain snake.
Apr 26, 2017 | Kenmore 17439 Built-in Dishwasher
Water not draining out of dishwasher
It can be clogged air lock or clogged hose somewhere next to the sink.
Good Luck
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Low water pressure
Take the impellors of (inside machine) and check to see if there is anythig clogging the wholes. Run the machine for a couple of minutes without impellors on and check around the sump and filter.
Dec 07, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Water still in the bottom of the dishwasher
If there is no air gap (silver cap) located on your sink next to your faucet, you could have a clog in the drain line or at the drain port at the motor/pump assembly. Also, check to see if the drain hose (under sink) has a loop in it before it goes to the disposal or pipe. If there is no loop, water could be backing up into the tub.
Sep 28, 2007 | GE GSD5320DBB Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
Owen Barnes
