Question about Brother HL-2040 Laser Printer
Failure to operate
When I turn the printer scanner on it will not perfrom any function. The three quality lights all blink at the same time. The Macintosh operating system reports that it is hooked up to the printer but when I try to print I eventually get a "No connection" report. I am in Clayton, Geeorgia. Is this unit worth tracking down a repair person?
Thanks in advance
Robert Fichter
    Problem Solver:
  • 5 Answers
Tell your system to make this printer it's "Default" printer
Posted on Jun 04, 2008
Canon ip7270 ink pads fuul
Hi
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
In Case You Still Having Brother Printer Problem Then Follow Us for On: Canon Printer Support
Cheers
Jan 24, 2014 | Office Equipment & Supplies
Error 5002 che cosa puo essere?
Sep 26, 2013 | Canon PIXMA iP3600 Photo Printer
Scanner failure
You should reset the printer
To reset it:
1.Unplug it (remove the cable physically) from wall or from back side of the unit
2.Keep two buttons down at the same time:
a.cancel button (pink one)
b.right arrow
Buttons have to be kept together!
3.Plug the printer again (don't release buttons!)
4.After that light under three large oval buttons should turn on for a second (short blink).
If that doesn't help - repeat it. If second trial fails - reinstall the driver which is located here or go to HP service.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 10, 2011 | HP PSC 2175 All-In-One InkJet Printer
Ink wast is full ,
Hi
Jun 13, 2010 | Canon i80 InkJet Printer
For Canon MP210 absorber is full
Three choices. 1. Take it in for repair. 2.Take the top off and remove and clean the pad. 3. Use the following instructions to reset the printer and continue printing. I chose number 3 and haven't had any problems.
These are the instructions which worked for me on my Canon ip470 and has work on many other Canon models:
Feb 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I have Canon MP760 Pixma printer message coming up 'waste ink absorber is almost full' can you tell me how to fix this?
Jan 21, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Cannon i80 - message Waste Ink Tank Full
Follow this procedure:
Don't forged to replace the waste ink absorption pad.
Oct 05, 2009 | Canon i80 InkJet Printer
Canon pixma mp-610
Try resetting the printer:
Jul 19, 2009 | Office Equipment & Supplies
Error 5100 canon ip90
You may try this to rest the 5100 error:
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
