Question about Saeco Vienna Espresso Machine
Timing is off. Can't unit back together the grars do not match
  • 3,083 Answers
This is going to be a tough deal to figure out, but we'll try I found a website that sells the gears, and perhaps if you contact them, they might be able to provide some assistance on the setup for the gear assembly. Here's the site:
http://www.partsguru.com/SaecoViennaBlack.html
Here is another gear vendor:
http://www.cafeparts.com/Product.asp?ItemID=76901
You might try contacting Saeco and see if they can assist you with a set of directions for setting the gears.
Their contact site is here:
http://www.saecosupport.com/contactus.html
Wish I had an exact procedure for you, but perhaps this will help.
Posted on Oct 12, 2010
On a 1999 Isuzu Rodeo 3.2 V6 DOHC If you put all timing marks together on engine and then put timing belt mark all together on the engine and rotate two rounds with crankshaft does all the marks come
Just the engine. The marks on the belt are to make sure the teeth are in the right place when replacing. It might come back in place on 4 turns of the crankshaft. I have never checked to see if the belt marks came back. But always check the timing marks themselves.
Hope this helps.
Nov 10, 2014 | 1999 Isuzu Rodeo
How do I set timing on a 2.3 Suzuki aerio engine
wow no job stated.
04 (2.3L) ill take a wild guess and say, you might be fiddling the cam
and doing something there, new cam, new lifters, new chain, new head, ? what?
FSM means factory service manual, ever heard of one?
the FSM is just lousy 4 bucks why not read that first. and not mess it up.
https://suzukipitstopplus.com/Products/1004-2004-aerio-service-manual.aspx
you said SET, so i can only assume its all apart. right then
you want to Instal the chain and time it, right so here are the fsm steps
no photos. log in and read the FSM for that.
  1. Check that match mark on crankshaft timing sprocket is in match with timing mark on lower crankcase.
  2. Install crankshaft timing sprocket as shown in figure.
  3. Apply oil to bush of idler sprocket and install idler sprocket and sprocket shaft.
  4. Install first timing chain by aligning dark blue plate of first timing chain and match mark on idler sprocket.
  5. Bring yellow plate of first timing chain into match with match mark on crankshaft timing sprocket.
  6. Apply engine oil to sliding surface of timing chain tensioner and then install it as shown in figure. Tighten tensioner nut to 18 ft. lbs. (25 Nm).
  7. With latch of tensioner adjuster No.1 returned and plunger pushed back into body, insert stopper into latch and body. After inserting it, check to make sure that plunger will not come out.
  8. Install timing chain tensioner adjuster No.1. Tighten the timing chain tensioner adjuster No. 1 bolt to 8 ft. lbs. (11 Nm).
  9. Pull out stopper from adjuster No.1.
  10. Apply engine oil to sliding surface of timing chain guide No.1 and then install it. Tighten guide bolts to 6.5 ft. lbs. (9 Nm).
  11. Check that dark blue and yellow plates of first timing chain are in match with match marks on sprockets respectively.
  12. Install second timing chain as follows:
    • Check that match mark on crank timing sprocket is in match with timing mark on lower crankcase.
    • Check that arrow mark on idler sprocket faces upward.
    • Check that knock pins of intake and exhaust camshafts are aligned with timing marks on cylinder head.
    • Install second timing chain by aligning yellow plate of second timing chain and match marks on idler sprocket.
    • Install sprockets to intake and exhaust camshafts by aligning dark blue plate of second timing chain, match marks on intake sprocket and exhaust sprocket respectively. NOTE As an arrow mark is provided on both sides, camshaft timing sprocket has no specific installation direction.
  • Install intake and exhaust camshaft timing sprocket bolts. To install it, fit a spanner to hexagonal part at the center of camshaft to hold it stationary. Tighten the camshaft timing sprocket bolt to 57.5 ft. lbs. (80 Nm).
  • Push back plunger into tensioner body and hold it at the position by inserting stopper into body.
  • Install timing chain tensioner adjuster No.2 with new gasket. Tighten the timing chain tensioner adjuster No. 2 bolts to 8 ft. lbs. (11 Nm) and No. 2 nut to 33 ft. lbs. (45 Nm).
  • Pull out stopper from timing chain tensioner adjuster No.2.
  • Turn crankshaft two rotations clockwise then align timing mark on crankshaft and timing mark on cylinder block.
  • Check that timing marks of cylinder head and cylinder block are in match with match marks on sprockets respectively.
  • Apply oil to timing chains, tensioner, tensioner adjusters, sprockets, and guides.
  • Install timing chain cover. Reverse removal sequence to install timing chain cover noting the following points:
    • Apply sealant "A" and "B" to area as shown.
      • "A": Sealant 99000-31250
      • "B": Sealant 99000-31140
    • Apply sealant amount to the following areas.
      • "a": 0.12 inches (3mm)
      • "b": 0.08 inches (2mm)
      • "c": 0.24 inches (6mm)
      • "d": 0.63 inches (16mm)
      • "e": 0.55 inches (14mm)
      • "f": 2.56 inches (65mm)
      • "g": 2.87 inches (73mm)
      • "h": 0.16 inches (4mm)
    • Apply engine oil to oil seal lip, then install timing chain cover. Tighten bolts and nut to 8 ft. lbs. (11 Nm).
      NOTE Before installing timing chain cover, check that pin is securely fitted.
    • Before installing timing chain cover, check that pin is securely fitted.
  • Install alternator belt idler pulley. Tighten nut to 30.5 ft. lbs. (42 Nm).
  • Install alternator belt tensioner. Tighten bolts to 18.5 ft. lbs. (25 Nm).
  • Install water pump pulley.
  • Install A/C compressor bracket (if equipped). Tighten bracket bolts to 40 ft. lbs. (55 Nm).
  • Install cylinder head cover with new gaskets and seal washers and tighten nuts to 8 ft. lbs. (11 Nm).
  • Install oil pan.
  • Install crankshaft pulley using pulley holder tool. Tighten the crankshaft pulley bolt to 108.5 ft. lbs. (150 Nm).
  • Install engine assembly.
  • Install all remaining components in the reverse order of the removal procedure.
did that cover it, surely not.
but if you get the FSM and read it or log in , you will not miss the photos and the complex sealing bs on this motor.
Oct 18, 2014 | 2004 Suzuki Aerio
Clutch dose not disengage when trying to put it in gear 98 goldwing
Is there air in the clutch line does it feel real spongy or is the clutch plates stuck together and won't release??
Apr 20, 2014 | 1998 Honda GL 1500 Aspencade Gold Wing
I put heads on a 89 MIT montero and times but still missing. Wondering if the timing might need advancing
I just did it, the distributor is two teeth back under #2 on the distributor cap!
I do not know why I just know it is, and I verified it at a local junk yard on two Montero's .
The three timing mark's must all match at their marks at the same time, if you have the car together then the white mark on your harmonic balancer should be at the mark on your timing cover at the bottom area of your engine
Jun 03, 2012 | 1989 Mitsubishi Montero
89 mitsubishi montero set timing marks on compression stroke and rotor button still wont start
Nov 01, 2010 | 1989 Mitsubishi Montero
What are the timing marks 1987 ford ranger 2.3
star with your crank pulley, fuond a notch mark it (witeout woks fine) then botton of timign cover mark 0, bring them together and check your distribuitor rotor points to spark plug cable for piston #1 first front to back, if not match your timimg belt jumped.
Oct 02, 2010 | 1987 Ford Ranger
Need to know how to change lower unit on 1971 johnson 25 hp motor
put into nuetral,undo the five bolts around lower unit,take off sideplate halfway down leg casing,loosen the two bolts clamping the gear rods together,then lower unit should slide down[if driveshaft isnt stuck in the crankshaft spline].assembly is reverse,but take care putting water tube back into rubber grommet,and tighten gear rod clamp only after making sure that g/box is in nuetral,when gear lever also in nuetral,or matched together
Jul 01, 2010 | Light Outboard Motor Boat Bass Fishing...
96 camry 2.2L, What timing marks do you use to
the 2 single dots on the inside of the gear(side facing the rear of the motor) When the gears mesh together the 2 dots should line up.
Sep 20, 2009 | 1993 Toyota Camry V6
Timing chain 110 hymoto pit bike
Put the piston at TDC (Top Dead Center) by lining up the timing marks on the flywheel and stator. Put the cylinder head back together with the cam installed so the high points of the cam lobes are pointing kind of downward. Pull the cam chain taught on the front side of the engine. Put the chain on the cam gear such that, when bolted to the cam, the index mark or marks are in the proper position.
The proper position depends on what markings are on the cam. Some bikes have a single mark; an arrow, a straight line or an "O". The mark should line up with the center-line of the crankshaft. If the cam has two marks opposite each other, the lines should be parallel with the gasket surface. You will need to rotate the unbolted cam left or right just a bit in order to match up the bolt holes to the gear holes.
Can I get a “very helpful” rating on this answer?
Aug 19, 2009 | 1984 Honda GL 1200 Gold Wing
Saeco Vienna Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
